Integrating velocity equation problem
11 replies · 2K views
Sho Kano
I've already completed the first question, but with number two, it's a different case. Here's my attempt:
[itex]\frac { d{ v }_{ y } }{ dt } \quad =\quad -g\quad -\quad \beta { v }_{ y }\\ \frac { d{ v }_{ y } }{ -g\quad -\quad \beta { v }_{ y } } \quad =\quad dt\\ \int { \frac { d{ v }_{ y } }{ -g\quad -\quad \beta { v }_{ y } } } \quad =\quad \int { dt } \\ \frac { -1 }{ \beta } ln(-g-\beta { v }_{ y })\quad =\quad t\\[/itex]
natural log of a negative?
EDIT: I seem to have figured out the answer right after posting this?
[itex]\frac { -1 }{ \beta } ln(-g-\beta { v }_{ y })\quad =\quad t\\ ln(-g-\beta { v }_{ y })\quad =\quad -t\beta \\ -g-\beta { v }_{ y }\quad =\quad { e }^{ -t\beta }[/itex]
Ssnow said:
In general ##\int \frac{1}{x} dx= \log{|x|}+c##
log base e right?
Sho Kano said:
##−g−βvy=e−tβ\frac { -1 }{ \beta } ln(-g-\beta { v }_{ y })\quad =\quad t\\ ln(-g-\beta { v }_{ y })\quad =\quad -t\beta \\ -g-\beta { v }_{ y }\quad =\quad { e }^{ -t\beta }##
if ##-g-\beta v_{y}>0## this is part of your solution, you must use the condition that ##v_{y0}=0##, but attention that you forgot the integration constant in your solution ...
The integration constant is just the initial condition, which is 0
mmm, I don't think, assuming ##-g-\beta v_{y}>0## put the condition ##v_{y}=0## with ##t=0## in
##\ln{(-g-\beta v_{y})}=-t\beta +c ##
You can see the value of ##c## also from ##\ln{|-g-\beta v_{y}|}=-t\beta + c##...
Ssnow, not sure I follow you. From post #1, 3rd line of my attempt, the limits of integration are:
left side: 0 to v
(its 0 since initial velocity is given to be 0)
right side: 0 to t
You forget the constant ##\ln{g}##:
##\int_{0}^{v_{y}}\frac{w}{-g-\beta w}=-\frac{1}{\beta}\ln{|-g-\beta v_{y}|}+\frac{1}{\beta}\ln{g}##
I see now, thanks!
