Integrating velocity with respect to time when velocity depends on position
The discussion revolves around the integration of velocity with respect to time when velocity is expressed as a function of position, V = V(x). Participants explore how to determine the transit time for a particle moving from point A to point B under these conditions.
  • One participant poses a problem regarding how to calculate the time taken for a particle to travel between two points when velocity is a function of position, V = V(x).
  • Another participant suggests using the relationship dx = v dt, leading to the conclusion that dt = dx/v, which can be integrated to find the total time.
  • A participant reflects on their understanding, noting that if velocity is expressed as a function of time, they would integrate v from 0 to t to find distance, while in the case of v = v(x), they would rearrange to express dt in terms of dx for integration.
  • One participant criticizes the lack of use of LaTeX for clarity in mathematical expressions, suggesting it would enhance communication.
  • A response to the criticism highlights a disagreement over the tone of the comment and defends the original poster's choice not to use LaTeX due to unfamiliarity.
Participants express differing views on the use of LaTeX for clarity, and there is a disagreement regarding the tone of feedback provided. The mathematical approach to integrating velocity with respect to time appears to be understood by some, but the discussion does not reach a consensus on the best practices for communication.
The discussion does not resolve the potential complexities involved in integrating velocity as a function of position, nor does it clarify assumptions about the forms of V(x) that may affect the integration process.
timsea81
Okay this seems like it should be simple but I'm stuck.
A particle moves from point A to point B in one dimension. The velocity of the particle changes with position according to some formula V = V(x). How long does it take for the particle to get from point A to point B?
If I could write V as a function of time, I could than integrate V=V(t) from 0 to t and that would give me the transit time. How do I do it if V depends on X?
Say, for example, V(X) = 1 + ax
dx=vdt, so dt=dx/v, integrate to find time
Thanks. That does it, and I think I understand it now. I was thinking of it backwards before.
If I have v=v(t), I can integrate v from 0 to t to get the total distance traveled. I already know time in that case. If I don't have time I'd have to solve this for t, set it equal to t, and solve. In this case v = dx/dt --> dx = v dt, so integrating v dt gives you x.
If I have v=v(x) I solve so that dx is at the end of the expression: dt = (1/v) dx so I can integrate with respect to x, the variable that I know.
why can't you guys bother to use [itex]\LaTeX[/itex] on this site that provides that resource?
it helps you articulate your question or answer. and it makes it easier for anyone to read either.
Why can't you bother capitalizing the first words of your sentences, or proofreading your post to realize that the word "either" was used wrong?
I don't know latex, that's why I didn't use it. Do you similarly not know the English language?
I guess I might say "thanks for the tip" had you not worded your response as a criticism.
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 41 ·
  • · Replies 49 ·
