Integrating xe^{ax}: A Step-by-Step Solution
  • Thread starter Radarithm
    Integrating
4 replies · 4K views · last reply
Radarithm
Evaluate: [tex]\int{xe^{ax}}dx[/tex]
Integration by substitution
I'm on a phone at the moment. My work: http://postimg.org/image/v4hdr5uqx/
The correct answer was:
[tex]\frac{xe^{ax}}{a}-\frac{e^{ax}}{a^2}[/tex]
You should do this integral by parts. Some of your original substitutions don't look OK.
http://postimg.org/image/ao3mi4ygz/
I feel like I'm getting closer but I'm still making a dumb mistake. Is it with the derivatives?
If [itex]dv = e^{ax} dx[/itex], then [itex]v = e^{ax}[/itex] is wrong. There are also multiple errors on the second line, but you need to fix what I said first.
Got it. Thanks for pointing out my mistakes.
[tex]\int{xe^{ax}}dx[/tex] [tex]u=x du=dx dv=e^{ax}dx v=\frac{e^{ax}}{a}[/tex]
[tex]\frac{xe^{ax}}{a}-\int{\frac{e^{ax}}{a}}dx[/tex]
[tex]\frac{xe^{ax}}{a}-\int{e^{ax}a^{-1}}dx=\frac{xe^{ax}}{a}-\frac{e^{ax}}{a^2}[/tex]
Power rule + derivative mistake
Thanks for the help.
