Integration by Parts definite integral
6 replies · 19K views · last reply
raptik
The definite integral of from 0 to 1 of ∫ (r3)dr/sqrt(4+r2)
∫udv = uv - ∫vdu
∫du/sqrt(a2 - u2) = arcsin(u/a) + C
∫du/(asqrt(a2 - u2)) = (1/a)arcsec(u/a) + C
I made u = (4+r2)-1/2
because I thought it easier to get it's derivative, rather than integral by making it dv.
du = -r(4+r2)-3/2dr
dv = r3dr
v = (1/4)r4
I've set up the equation as
= uv -∫vdu
= r4/(4(4+r2)1/2) + ∫r3dr/(4+r2)3/2
This seems somewhat similar to the the second equation I put in "Relevant Equations" (where I could put a two in the numerator and multiply the integral by (1/2), but both top and bottom are to the power of 3 (which I don't know how to get rid of. AND the bottom is not a2 - u2 but a2 + u2.If somebody could please help me understand this I would be greatly appreciative. I'd like to be able to master this type of integration, but I seem to have hit a wall.
It's a LOT easier if you just work it through with the u substitution u=4+r^2.
What about letting u=x^3 and v=1/sqrt(4+r^2): to obtain:
[tex] \int_{0}^{1}\frac{r^{3}}{\sqrt{4+r^{2}}}dr=\left[ r^{3}\sinh^{-1}(r/2)\right]_{0}^{1}-3\int_{0}^{1}r^{2}\sinh^{-1}(r/2)dr[/tex]
but according to integration by parts, 1/sqrt(4+r^2) must be dv not v, if you make u = x^3. Also I did not follow how you got the sinh^{-1}(r/2) if the denominator is (a2 + u2)1/2 not (a2 - u2)1/2
I see what you did for the most part, except that last issue I mentioned. Thnx.
Okay, look at the integral:
[tex] \int\frac{dx}{\sqrt{a^{2}+x^{2}}}[/tex]
Use the substitution [tex]x=a\sinh u[/tex] and the integral reduces down to:
[tex] \int du=u=\sinh^{-1}\left(\frac{x}{a}\right)[/tex]
It's a standard integral
That was what hunt_mat meant.
That is exactly the point! If it were [itex]\sqrt{a^2- u^2}[/itex], then the integral would be [itex]sin^{-1}(x)[/itex]. But because it is "+" rather than "-" it is the hyperbolic rather than regular sine.
du = -r(4+r2)-3/2dr
dv = r3dr
v = (1/4)r4
= uv -∫vdu
The integral that resulted when you did integration by parts,
[tex]\int_{0}^{1}\frac{r^{3}}{(4+r^{2})^{3/2}}dr\,,\[/tex] is more difficult to integrate than the integral you started with:
[tex]\int \frac{r^{3}}{(4+r^{2})^{1/2}}dr\,.[/tex]
This suggests reversing the roles of u & v to the extent that you can do that. Integrating [tex](4+r^{2})^{-1/2}[/tex] will result in something with a factor of [tex](4+r^{2})^{1/2}[/tex]. In fact, although this is a little unusual, you can pick what you want v to be, then differentiate that to see if the dv which results is usable.
Let [tex]\textstyle v=(4+r^{2})^{1/2}[/tex], then [tex]\textstyle dv=r(4+r^{2})^{-1/2}\, dr\,.[/tex] This will work out just fine!
Therefore, let [tex]\textstyle dv=r(4+r^{2})^{-1/2}\,dr\ \ \to\ \ v=(4+r^{2})^{1/2}\,.[/tex]
This leaves [tex]\textstyle u=r^2\ \ \to\ \ du=2r\,dr,.[/tex]
[tex]\int u\ dv=\int (r^2)\left(r(4+r^{2})^{-1/2}\right)\,dr[/tex] [tex]\text{, and } \int v\ du=2\int (r)\left((4+r^{2})^{1/2}\right)\,dr[/tex]
The integral [tex]\int r\,(4+r^{2})^{1/2}\,dr[/tex] is easily evaluated with a simple substitution.
