Integration by substitution for sin/cos products
The integral of sin x (cos x)^3 can be approached using two different substitutions, u = cos x and u = sin x, leading to seemingly different results. However, both methods yield equivalent expressions differing only by a constant of integration. The first substitution results in -(1/4)(cos x)^4 + C, while the second yields (1/2)(sin x)^2 - (1/4)(sin x)^4 + C. By manipulating the expressions, it can be shown that they are indeed the same. This illustrates the nature of indefinite integrals, where multiple forms can represent the same function.
phoneketchup
Ok so I might be doing something silly but I just don't understand what is going on here. So the integral:
i = ∫ sin x (cos x)^3 dx
First I say u = cos x. So du = - sin x dx.
So now I have i = ∫ - u^3 du. Which gives: i = -(1/4)u^4 or -(1/4)(cos x)^4. Easy.
But if I say u = sin x instead, this is what happens:
So du = cos x dx. And I say i = ∫ sin x (cos x)^2 cos x dx.
So I have i = ∫ u(1 - u^2) du or i = ∫ (u - u^3) du. WHAT.
Why am I getting two different answers?? Which one is right and why?
Thanks!
Mathematics news on Phys.org
Actually, it doesn't. It gives -(1/4)(cos x)^4+ C for any constant C.
Thanks!
You are not getting two different answers. The integral of "u- u^3" is (1/2)u^2- (1/4)u^4+ c which is equal to (1/2)(sin x)^2- (1/4)(sin x)^4+ c.
See what happens if you replace (sin x)^2 by 1- (cos x)^2 in that last formula.
Actually you get the same answer. In fact when you put u=\sin(x) you get <br /> \int u-u^3\,du=\frac{u^2}{2}-\frac{u^4}{4}+c=\frac{\sin(x)^2}{2}-\frac{\sin(x)^4}{4}+c<br />
now, if you work on the first result you got, you'll see that: <br /> -\frac{\cos(x)^4}{4}+c=-\frac{(\cos(x)^2)^2}{4}+c=-\frac{(1-\sin(x)^2)^2}{4}+c=\frac{\sin(x)^2}{2}-\frac{\sin(x)^4}{4}+\frac{1}{4}+c<br />
The two results are the same because it is an indefinite integral and they differ by an arbitrary constant. It could also have been solved without substitution noticing that \cos(x)^2=1-\sin(x)^2 and that D[f(g(x)]=f&#039;(g(x)) g&#039;(x)
Didn't realize we replied at the same time, sorry
Oops! I forgot to put the constant of integration. And yeah I see now.. it was pretty silly haha. Thanks! :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
