How can I integrate this function using substitution?
The discussion focuses on evaluating the definite integral of sin(t)/t from 1 to 2 using substitution. The original poster struggles with appropriate substitutions, initially trying u=sin(t) and u=1/t, but finds them unhelpful. They express uncertainty about whether integration by parts is the right approach for the remaining integral. Participants provide guidance on using LaTeX for formatting the integral notation and suggest that the problem may require more advanced techniques beyond basic integration methods. The conversation highlights the challenges of integrating this specific function and the need for alternative strategies.
ada0713
Evaluate the definate integral of the following
\int (from 1 to 2) \frac{sin t}{t} dt
I am actually stuch from the very beginning.
I tried to set u=sin(t) but this doesn't help much because (sint)'=cost and
this is going to make the problem more complicated.
I also set u=1/t but the derivative of 1/t has nothing to do with
the function as well.
(Perhaps I shouldn't integrate the function by substitution)
Please help me with the start!
I set:
u=sint dv=1/t dt
du=-cost v=lnltl
\int [from 1 to 2] (sint)(1/t) dt
= [(sint)(lnltl)]^{1}_{2} -\int[from 1 to 2] lnltl (-cost)
How do I integrate the red part?
should I do the by parts again?
Well...I do not think there is any closed form of that integral.(To my knowledge) You may need something more than integration by parts.
For your latex
\int_1^2
\frac 1 t or \frac{1}{t} - use the brackets when you have more than one letter per term
Or maybe you were lazy :-p
roco, where did you learn the \int_1^2 notation? I never figured it out, at least not from the latex code reference PDF file.
\int_1^2
Click on the latex and you will see the code.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 105 ·
