Integration of a complicated sort
  • Thread starter Thread starter mateomy
    Integration Sort
8 replies · 3K views · last reply
mateomy
Here's the original problem in all of its glory...
[tex] \int_0^{T/2} \,\sin((2\pi(t)/T) - \alpha) \, dt[/tex]
U Substitution
Trig identities (possibly)
Using U substitution I've got u=[itex]2\pi(t)/T -\alpha[/itex]
Which means that du= [itex]2\pi/T dt[/itex]
Which also means that dt= [itex]Tdu/2\pi[/itex]
and resetting the limits of integration I have an upper bound at [itex]2\pi - \alpha[/itex] and a lower bound of [itex]-\alpha[/itex].
So now my little equation looks like this...
[tex] \int_{-\alpha}^{2\pi - \alpha} \, \sinu \,\frac{T}{2\pi}\,du[/tex]
pulling out the [itex]T/2\pi[/itex]...
[tex] \frac{T}{2\pi}\int_{-\alpha}^{2\pi -\alpha} \,\sinu \,du[/tex]
which using the Fundamental Theorem of Calculus I can turn to...
[tex] \frac{T}{2\pi} \, (-\cos(u)) [/tex]
evaluating at the upper minus the lower bound (previously stated)
Which looks something like this...
[tex] -\frac{T}{2\pi}\Big(\cos[\,2\pi\,-\,\alpha] - \cos[-\alpha]\Big)[/tex]
Can I use a trigonometric identity to break this thing apart?
When I try to do that I get this...
[tex] -\frac{T}{2\pi}\,\Big(\cos(2\pi)\cos(\alpha)\,+\,\sin(2\pi)sin(\alpha)\,+\,\cos(\alpha)\Big)[/tex]
All in all I end up with a final answer of
[tex] -\frac{T}{2\pi}\,2\cos(\alpha)[/tex]
I have no answer to check my work, so that's why I am posting it here for everyone to point out my probable mistakes and give me some advice. Thanks a ton for the help/suggestions.
Sorry if my Latex is screwed up in some places.And on second glance...would this end up being a 0 in the end because the Integration with the new U substitution turns out to be an odd function? Or am I closer to being right the first time?
Fixed your first integral...I think.
[tex] \int_0^{T/2} sin(2\pi(t)/T - \alpha) \, dt[/tex]
U Substitution
[tex] \int_-\alpha^(2\pi - \alpha) \, \sinu \,\frac{T}{2\pi}\,du[/tex]
[tex] \frac{T}{2\pi}\int_-\alpha^(2\pi -\alpha) \,\sinu \,du[/tex]
[tex] \frac{T}{2\pi} \, -\cos(u) [/tex]
Yeah you fixed it. I'll try to work out the other integrals using your code as an example.
THANKS!
U Substitution
You have an error in the line above. Inside the parentheses it should be cos(pi - alpha) - cos(-alpha)
cos(pi - alpha) = -cos(alpha) and cos(-alpha) = cos(alpha)
I end up with (T/pi)cos(alpha).
Okay, so I am close...
Im looking at the point where I pulled the antiderivative of sin(u), which I thought was a (neg)cos(u). So wouldn't I want to pull it all the way out in front of my constant [itex]\frac{T}{2\pi}[/itex]?
Im also lost on how you reached a pi as opposed to the 2pi I have come to?
But seriously, thanks.
I meant that in sense of what was in the parenthesis, not the final answer; because, correct me if I am wrong but the 2pi in the denominator and 2cos would simplify to a pi in the denominator and a singular cosine.
When you evaluate cos(2pit/T - alpha) at t = T/2, you get cos((2pi/T)(T/2) - alpha). The 2's cancel and the T's cancel, so you're left with cos(pi - alpha).
