Integration of complex exponentials
  • Context: Graduate
  • Thread starter Thread starter spaghetti3451
    Complex Integration
1 reply · 1K views
spaghetti3451
I am trying to understand how to go from the first line to the next:
##\frac{1}{(2\pi)^{3}}\int d^{3}p\ e^{-it\sqrt{{\bf{p}}^{2}+m^{2}}}\ e^{i {\bf{p}}({\bf{x}}-{\bf{x}}_{0})} = \frac{1}{2\pi^{2}|{\bf{x}}-{\bf{x}}_{0}|} \int_{0}^{\infty} dp\ p\ sin(p|{\bf{x}}-{\bf{x}}_{0}|)\ e^{-it\sqrt{{p}^{2}+m^{2}}}##.
As an initial guess, I'm thinking that the vector ##\bf{p}## is decomposed in spherical polar coordinates, evidenced by the facts that ##\frac{1}{(2\pi)^{3}}## has been multiplied by ##4\pi## and that the volume element is afterwards ##dp\ p## with limits from ##0## from ##\infty##. Also, I'm thinking that firstly the exponential ##e^{i {\bf{p}}({\bf{x}}-{\bf{x}}_{0})}## is broken using Euler's relation into its sine and cosine components.
I wonder what's happened to the cosine component, the factor of ##i## in the sine component, how the polar and azimuthal angles have been separated out from the vector expression ##-it\sqrt{{\bf{p}}^{2}+m^{2}}## and how the factor of ##|{\bf{x}}-{\bf{x}}_{0}|## in the denominator outside the integral appears.
I can help with this bit:
The expression ##{\bf{p}}^{2}## is more correctly written ##\|\bf{p}\|^2##, which is equal to ##p^2##. Hence
##-it\sqrt{{\bf{p}}^{2}+m^{2}}## can simply be replaced by ##-it\sqrt{{p}^{2}+m^{2}}##
I think this will be something to do with the following:
Convert the integral into
$$\int_0^\infty \left[\int_{N_p} f(p,\phi,\theta) dA + \int_{S_p} f(p,\phi,\theta) dA\right]\,dp$$
where ##N_p## and ##S_p## are respectively the Northern and Southern hemispheres of the sphere of radius ##p##.
Then think about what cancels out between the two hemispheric integrals when you match antipodal points.
