Integration Problem: Showing Integral Equals 1
  • Thread starter Thread starter Mogarrr
    Integration
9 replies · 2K views
Mogarrr
I'm trying to show that the definite integral:
[itex]\int_0^{\infty} \frac 1{\sqrt{2 \pi}} \sqrt {y} e^{\frac {-y}2} dy[/itex],
equals 1.
it's already known that [itex]\int_0^{\infty}\frac 1{\sqrt{2 \pi}} y^{\frac {-1}2} e^{\frac {-y}2} dy = 1[/itex], since f(x) is a probability density function.
I've tried integration by parts, but that hasn't helped.
[itex]\int_0^{\infty} \frac 1{\sqrt{2 \pi}} \sqrt {y} e^{\frac {-y}2} dy = \frac 1{\sqrt{2 \pi}} (-2 \sqrt {y} e^{\frac {-y}2})|_0^{\infty} + \int_0^{\infty}\frac 1{\sqrt{2 \pi}} y^{\frac {-1}2} e^{\frac {-y}2} dy[/itex],
but [itex]lim_{t \to \infty} -2 \sqrt {y} e^{\frac {-y}2})|_0^{\infty} = 0[/itex], so that's not very helpful.
Any ideas to evaluate the integral?
equals 1.
but [itex]lim_{t \to \infty} -2 \sqrt {y} e^{\frac {-y}2})|_0^{t} = 0[/itex], so that's not very helpful.
(Fixed a little typo there.)​
If you know that [itex]\int_0^{\infty}\frac 1{\sqrt{2 \pi}} y^{\frac {-1}2} e^{\frac {-y}2} dy = 1 \ ,\[/itex] then it seems to me that you have all but arrived at the result.
I believe Mogarr knows that it equals 1, though doesn't analytically know how to demonstrate that with standard integration techniques.
That's right
SammyS said:
So, which part of this problem are you having difficulty with.
Please be specific.
I'm having a problem finding a method to evaluate:
[itex]\int_0^{\infty} y \frac 1{\sqrt {2\pi}} \cdot y^{\frac {-1}2} e^{\frac {-y}2} dy =\int_0^{\infty} \frac 1{\sqrt {2\pi}} \cdot y^{\frac 12} e^{\frac {-y}2} dy[/itex].
Here's some background. I know that the integral should evaluate to 1. In a previous part of the problem, I saw that for this standard normal function,
[itex]f_X(x) = (\frac 1{\sqrt {2\pi}}) e^{\frac {-x}2}[/itex],
the expected value of the random variable squared, [itex]E X^2[/itex], is equal to 1. I had to look at the answer to solve this problem. The integral I am trying to solve is the expected value of Y, [itex]E Y[/itex], where [itex]Y = X^2[/itex]. So this is a transformation of the random variable, but the result should be the same as [itex]E X^2[/itex] (this was stated in the problem description).
The conundrum I have is, after seeing the answer, I don't believe it to be true. Here is the answer given (hopefully without typos) in equations and italics:
[itex]E Y = \int_0^{\infty} \frac {Y}{\sqrt {2\pi y}}e^{\frac {-y}2} dy = \frac 1{2\pi} (-2y^{\frac 12}e^{\frac {-y}2}|_0^{\infty} + \int_0^{\infty} y^{\frac {-1}2}e^{\frac {-y}2}dy) = \frac 1{\sqrt {2\pi}} \cdot \sqrt {2\pi} = 1[/itex].
This was obtained using integration by parts with [itex]u=2y^{\frac 12}[/itex] and [itex]dv= \frac 12 e^{\frac {-y}2}[/itex], and the fact that [itex]f_Y(y)[/itex] integrates to 1.
I don't think this answer is right though.
Isn't [itex]-2y^{\frac 12} e^{\frac {-y}2} |_0^{\infty} = 0[/itex] ? And if I am right, then I am fresh out of ideas to solve this problem.
If we make a simple substitution, [itex]u = \sqrt{y}[/itex], then we can see that $$\int \frac{1}{2\sqrt{y}}e^{-y/2}dy = \int e^{-u^2/2}du $$, what does that tell you about the integral itself?
I think I'm getting really close, but thus far...
[itex]\int_0^{\infty} \sqrt {y} e^{\frac {-y}2} dy = 2\sqrt {y} (-e^{\frac {-y}2})|_0^{\infty} + \int_0^{\infty} \frac 1{\sqrt {y}} e^{\frac {-y}2} dy[/itex]
where I did integration by parts with [itex]u = 2\sqrt {y}[/itex] and [itex]dv = \frac 12e^{\frac {-y}2} dy[/itex].
The first part of the sum is 0. So continuing on...
[itex]\int_0^{\infty} \frac 1{\sqrt {y}} e^{\frac {-y}2} dy[/itex] can be simplified with a u-substitution. If I let [itex]u = \sqrt {y}[/itex], then [itex]du = \frac 12 y^{\frac {-1}2}dy[/itex], and the limits of integration won't change.
So [itex]\int_0^{\infty} \frac 1{\sqrt {y}} e^{\frac {-y}2} dy = 2 \int_0^{\infty} e^{-y/2} \frac 12 \frac 1{\sqrt {y}} dy = 2\int_0^{\infty} e^{\frac {-(u)^2}2}du[/itex],
but [itex]2\int_0^{\infty} e^{\frac {-(u)^2}2}du = 2 \cdot \sqrt {2\pi}[/itex], where I need it to be [itex]\sqrt {2\pi}[/itex] so the whole thing can evaluate to 1.
I think a mistake was made. Don't know where though.
You can do it in two ways:
(1) recognize that ##\sqrt{y} \exp(-y/2) = y^{3/2 - 1} \exp(-y/2)## is proportional to the density function of the Gamma random variable G(3/2,1/2); see, eg., http://en.wikipedia.org/wiki/Gamma_distribution . You can then reduce the integral to a something involving ##\Gamma(3/2) = (1/2) \Gamma(1/2)## and use the known value of ##\Gamma(1/2)## (or work it out yourself).
(2) Use the change of variable ##y = x^2## to get ##c \int_0^{\infty} x^2 \exp(-x^2/2) \, dx## for a constant ##c##; then you need to know that the standard normal random variable has variance = 1, as you have already mentioned. The easiest way to get that is to use integration by parts:
[tex]\int x^2 e^{-x^2/2} \, dx = \int u dv, \\<br /> u = x, \: dv = x e^{-x^2/2} \, dx = d \left(- e^{-x^2/2} \right)[/tex]
I found my mistake. I found this from Wikipedia:
[itex]\int_0^{\infty} e^{-ax^{b}}dx = \frac 1{b} a^{\frac {-1}{b}} \Gamma (\frac 1{b})[/itex]
So after doing looking back at the u-substitution, I completed the problem. Thanks.
