Solving Integration Problem with Double Integral in Polar Coordinates
  • Thread starter Thread starter JaysFan31
    Integration
The discussion revolves around solving a double integral involving the expression 2(sqrt(9-x^2-y^2)(-x^2+y^2-2)) with the constraint x^2+y^2 ≥ 2. The integral is deemed impossible to compute using Cartesian coordinates, prompting the need for a polar coordinate approach. Participants clarify that the integral represents a region on the surface of a sphere defined by x^2+y^2+z^2=9, specifically where x^2+y^2 is greater than or equal to 2. The vector field involved is defined as (-y, x, xyz), and the curl of this vector field is calculated to facilitate the integration process. The discussion highlights the complexity of the problem and the necessity of substituting z with sqrt(9-x^2-y^2) in the calculations.
JaysFan31
I need to integrate
double integral 2(sqrt(9-x^2-y^2)(-x^2+y^2-2)dxdy with the bounds determined by the fact that x^2+y^2 is greater than or equal to 2.
This integral is impossible to calculate using cartesian coordinates. How would I do it using polar coordinates?
\int \!\!\! \int 2\sqrt{(9-x^2-y^2)(-x^2+y^2-2)}\,dx\,dy
x^2 + y^2 \geq 2
Is that the integral in question?
That's an infinite region isn't it?
Yes that's it, the one cepheid wrote.
Well it's obviously part of a problem so here goes:
Let S be the subset of the surface of the sphere x^2+y^2+z^2=9 for which x^2+y^2 is greater than or equal to 2. Let F be the vector field defined by (-y, x, xyz).
Computer double integral(curlF)*ndS where * is the dot product and S is oriented so that the unit normal n to S points away from the enclosed volume.
I have the vector field= -yi+xj+xjzk.
curlF (after calculation)=xzi-yzj+2k
G(x,y,z)=9-z^2-x^2-y^2 and gradG=-2xi-2yj-2zk
Thus, dS=(-2xi-2yj-2zk)dxdy
The dot product of curlF and dS=-2(x^2)z+2(y^2)z-4z
I plug in for z=sqrt(9-x^2-y^2) and I'm in this predicament.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
  • · Replies 24 ·
