Integration to d density function
benoardo
I have a problem with an integration, namely:
Int(from 0 to x) (1-F(x-t)) dF(x)
and do not know how to calculate...:-(
If it help,s dF(x) = (dF/dx)dx
It helps, but that mean to multiply the integrand by the density f=dF/dx and then integrate over dx, so like how to derive the expectation...
but another problem is, that I do not know the density and need to have a result within F(x)
Well, you can do it, though you do'nt think you can. so let#'s play a littel game.
What's the integral of 1 with respect to x? 1 wrt y? 1 wrt F(x)?
Now what's the integral of x wrt x? y wrt y, F(s) wrt F(s)?
Note, I don't think you want an x in the integrand and in the limit.
That's almost all clear but in my book i read that F(s) wrt F(s) is something like F(s)*F(s) which stands here for the convolution...
And i have a x in the itegrand as well as in the limit.
As I said before: int(0 to x) 1-F(x-t) wrt F(t), sorry so you are write, it is F(t) not F(x)!
Thank you very much for your support, but yesterday i found the answer in my stochastic I scriptum...if someone is interested in:
Let x, y be independent rvs with dfs F and G then holds for the distribuntion of the sum x+y:
H(a)=P(x+y<=a)=int F(a-v)dG(v).
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
