Integration using Hyperbolic Trig substitution
5 replies · 8K views · last reply
Krash
Evaluate:
[tex]\int\\{1}/{\sqrt{x^2-1}}[/tex] dx between -3, -2
I know I'm supposed to use hyperbolic substitution in the question.
edit: cosh^2(t) - sinh^2(t) = 1
let x = -cosht, inside the integral let dx = sinh(t) dt
int ( sinht / sqrt(cosh^2t - 1) ) dt
now normally at this point i would use the trig identity cosh^2(t) + sinh^2(t) = 1 to eliminate the -1 in the root, however i can't work out how to sub into eliminate because I've had to use a negative cosht for x as the bounds of the integral are both negative.
I'm not great at this area of maths, I thought maybe if i substituted sinh(t) for x, I could possible rewrite -sinh(t) as sinh(-t) but I'm not sure if that's a fair solution or not.
cheers.
that still means i can't sub cosht for x but i can use sinh = x
then everything cancels and I am left with int dt
which is -sinh^-1(x)
which gives me:
(1 / (-sinh(-3))) - (1 / (-sinh(-2))) = -0.175898995
still not sure if this is technically accurate
this is the current solution I am working on:
dx = cosht dt
x = -sinht
therefore;
1/ sqrt(x^2 - 1 ) = cosht dt / sqrt( -sinh^2 t - 1 ) ----- (1)
using the trig id:
cosh^2 t - sinh^2 t = 1
-sinh^2 t = -cosh^2 t + 1 ----- (2)
(2) into (1)
int (cosht / sqrt(-cosh^2 t)) dt = int dt
int dt = t + c
t = 1/(-sinh x)
therefore the integral evaluated is:
so if you have [itex]\int dt =t +c[/itex]
and x=cosh(t), doesn't it mean that t=cosh-1(x) ?
Sorry, x = -sinht, because the domain of the integral is negative.
i switched around the dx and x substitutions the second time around.
