Integration using Partial Fractions
The discussion revolves around integration techniques, specifically focusing on the use of partial fractions to evaluate integrals. Participants are addressing two separate integral problems involving rational functions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the process of splitting integrals into partial fractions and the subsequent integration steps. Some express uncertainty about their integration results and seek clarification on specific integral forms. Others question the correctness of their approaches and the handling of logarithmic expressions.
Several participants have offered guidance on integration techniques and the proper use of logarithmic identities. There is an ongoing exploration of different interpretations of the integrals, with some participants acknowledging mistakes in their calculations while others seek further assistance.
There are mentions of specific limits and the need for absolute values in logarithmic functions to ensure well-defined results. Some participants are also addressing potential errors in the setup of their integrals.
Hootenanny
Staff Emeritus
I need to find the following intergral:
\int_{0}^{1} \frac{28x^2}{(2x+1)(3-x)} \;\; dx
So I split it into partial fractions thus:
\frac{2}{2x+1} + \frac{36}{3-x} - 14
Then integrated:
\int_{0}^{1} \frac{2}{2x+1} + \frac{36}{3-x} - 14 \;\; dx
= \left[ \ln\left| 2x+1 \right| + 12\ln\left| 2-x \right| - 14x \right]_{0}^{1}
But this isn't going to give me the correct answer which is quoted as:
37\ln 3 - 36\ln 2 - 14
Can anybody see where I've gone wrong? Thank's
Sorry just a correction in my answer:
= \left[ \ln\left| 2x+1 \right| + 12\ln\left| 3-x \right| - 14x \right]_{0}^{1}
Your partial fraction expansion is ok. However, you integrated \frac{36}{3 - x} incorrectly.
Ahh yes. Thank-you, I realize what I've done now.
Is there any standard intergral in the form of \int \frac{a}{b+x} = ... because at the moment I'm not sure what to do. If anybody could guide me through it?
I suppose you can use \int\frac{a}{b\pm x}dx=\pm a\ln|x\pm b|
- Kamataat
Thank you very much.
hi there, I was wondering if you could possibly help me with an integration problem
\int_{1/4}^{-1/4} \frac{1}{(1-4x^2)} \;\; dx
i managed to split it into partial fractions and hence split up the integration as follows
\frac{1}{2} \int_{1/4}^{-1/4} \frac{1}{2x+1} - \frac{1}{2x-1} \;\;dx
after this i integrated it in the following manner but I am unsure as to whether it is right, and if so, how to continue it.
[\frac{1}{2} (\frac{1}{2}\ln(2x+1)-\frac{1}{2}\ln(2x-1))]still between the same two limits
Can anyone offer a hand?
if my integration was correct please continue reading this post, if not then it doesn't matter!
I broke down that inegraton to read
[\frac{1}{2} \ln\frac{2x+1}{2x-1}] limits \pm\frac{1}{4}
i then simplified this down to the following (including limit values)
\frac{1}{2} \ln\frac{1.5}{-0.5} - \frac{1}{2}\ln\frac{0.5}{-1.5}
Using the rules of logs i calculated this to be
\ln\frac{-3}{\frac{-1}{3}}
Giving a final answer of \ln9
Does anyone know if this is the correct answer or have i gone about it in the wrong way?
The correct answer is
\frac{1}{4} \left(\ln|2x+1|-\ln|-2x+1|\right)
you need the absolute values in \ln(x) in order to be well defined.
See Kamataat's post \int\frac{a}{b\pm x}dx=\pm a\ln|x\pm b|
well you have \frac{1}{1-4x^2}
so it should become
\frac{1}{(1+2x)(1-2x)}
if you want to write it as (2x+1)(2x-1), then you have to factor out a negative
you have it the other way around, i even checked it on my calculator and my answer matches:
after integrating it should become
\frac{1}{4}\left[\ln\left|\frac{1-2x}{1+2x}\right|\right]_{.25}^{-.25}
thanks
  • · Replies 105 ·
