Integration using substitution
The discussion revolves around solving the integral $$\int\frac{x^2+3}{x^6(x^2+1)}dx$$ using substitution and partial fractions. One participant successfully solved it using partial fractions but questioned if there was a simpler method. Suggestions included breaking the integral into simpler parts and using substitution with \( u = x^2 \) to facilitate the process. The conversation highlighted that while partial fractions can be tedious, combining them with substitution may streamline the solution. Ultimately, the consensus is that both methods can be effective, depending on the approach taken.
AdityaDev
None
I easily got the answer using partial fractions by splitting the integral as ##\frac{Ax+B}{x^2+1}+\frac{C}{x}+\frac{D}{x^2}+\frac{E}{x^3}+...+\frac{H}{x^6}## and then finding the coefficients by equating the numerator ##x^2+3## with the one obtained using partial fractions by taking LCM.
But is there an easier method?
None
The only "easier" method I can think of would be an ordinary substitution. Maybe there is one, but if there is, I don't see it. For this integral I would do exactly what you did.
Likes AdityaDev
Break up the integral:
$$\int \frac{x^2 + 3}{x^6(x^2 + 1)} dx = \int \frac{1}{x^4(x^2 + 1)} dx + \int \frac{3}{x^6(x^2 + 1)} dx$$
Maybe a different split:
##\displaystyle\ \frac{x^2+3}{x^6(x^2+1)}=\frac{x^2+1}{x^6(x^2+1)}+\frac{2}{x^6(x^2+1)}=\frac{1}{x^6}+\frac{2}{x^6(x^2+1)}\ ##
Then noticing that the title of the thread is "Integration using substitution" and not "Integration by substitution" ... (maybe not intended but try it)
Simplify ##\displaystyle\ \frac{2}{x^6(x^2+1)}\ ## by letting ##\ u=x^2\ .## Just do this to aid in manipulating the rational expression.
This gives: ##\displaystyle\ \frac{2}{u^3(u+1)}\ ##
Do partial fraction decomposition, or use the following reduction:
##\displaystyle\ \frac{1}{u^n(u+1)}=\frac{1}{u^n}-\frac{1}{u^{n-1}(u+1)}\ ## (repeatedly).
Of course change ##\ u\ ## back to ##\ x^2\ ## before integrating.
You can split it like this (better method): $$\frac{3x^2+3-2x^2}{x^6(x^2+1)}=\frac{3(x^2+1)-2x^2}{x^6(x^2+1)}=\frac{3(x^2+1)}{x^6(x^2+1)}-2\frac{x^2}{x^6(x^2+1)}=3\frac{1}{x^6}-2\frac{1}{x^4(x^2+1)}$$
I hesitate to put this up, but can't resist.
##\displaystyle\ \frac{3+x^2}{x^6(1+x^2)}=\frac{3+3x^2-2x^2}{x^6(1+x^2)} ##
##\displaystyle\ =\frac{3+3x^2-2x^2-2x^4+2x^4+2x^6-2x^6}{x^6(1+x^2)} ##
##\displaystyle\ =\frac{3(1+x^2)-2x^2(1+x^2)+2x^4(1+x^2)-2x^6}{x^6(1+x^2)} ##​
Just a different way to get the partial fraction decomposition, I suppose.
Likes AdityaDev
You get the the same thing if you use partial fractions like i did in post 0#
AdityaDev said:
You get the the same thing if you use partial fractions like i did in post #1
I would hope so.
The partial fraction method often seems rather tedious to me. I'm not sure this was any better.
Doing the substitution, u = x2 like I suggest in post #4 above could make the partial fraction thing easier, especially after using the split you suggested.
Likes AdityaDev
  • · Replies 105 ·
