Integration with fraction and square root
The discussion revolves around integrating the function (4x + 7) / √(-4x² + 20x - 9). A suggested substitution is u = -4x² + 20x - 9, leading to du = (-8x + 20)dx. The numerator can be rewritten as 4x - 10 + 17, allowing the integral to be split into two parts. The first integral simplifies to -1/2 ∫ du/u^(1/2), while the second may require a trigonometric substitution. Overall, the integration process involves strategic substitutions to handle the square root in the denominator.
Dell
i am given this function and need to integrate it
\frac{4x+7}{\sqrt{-4x^2+20x-9}}
i have been trying to intergrate it by calling something T, preferably the expression under the sqrd root, or part thereof (-4x2+20x=T) but i can't find the way to do this, can't find the best expression that fits both the denominator and numerator of the fraction.. any other ideas??
Try u = -4x^2 + 20x - 9, and du = (-8x + 20)dx (I like u for substitutions better than T.)
Your numerator is 4x + 7 = 4x -10 + 17, so your integral can be rewritten as two integrals.
\int \frac{4x - 10}{\sqrt{-4x^2 + 20x - 9}}dx + \int \frac{17}{\sqrt{-4x^2 + 20x - 9}}dx
Applying the substitution in the first integral, we have -1/2\int du/u^{1/2}. The second one is probably amenable to a trig substitution.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
