How Do Integration and Differentiation Function in Electronic PID Controllers?
  • Thread starter Thread starter cks
Integration and differentiation in electronic PID controllers are crucial for stabilizing systems like diode lasers. The integration process helps lock the frequency by adjusting the cavity length with a piezo, while differentiation addresses error signals when they exceed proportional limits. Differentiation in this context refers to the rate of change of the error signal, not merely the mathematical differentiation of a graph. The integral component operates within the proportional limits to ensure stability. Understanding these functions is essential for effective PID control in electronic applications.
cks
I'm curious about what does really integration and differentiation mean in electronic stuff like PID controller.
In the frequency stabilization of diode laser, the cavity length is changing by applying a sinusoidal voltage to the piezo attached to it. By turning the piezo integrator of the PID controller, I'm able to lock the frequency to a fixed frequency.
The example may not necessary point to PI controller.
Differentiation means differentiation of a curve? This also mean the same thing in PID controller? Let's say a laser give an absorption wave profile of an atom, differentation means to differentiate the graph shown on the oscilloscope?
Thank you.
For PID control this differential part is for when you go outside your proportional limits. The error signal will have a gain associated with it causing the controller to accelerate the error signal (difference in actual from set-point) to zero. Note; the integral limits will be inside the proportional limits.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
