Integrators and Differentiators
  • Thread starter Thread starter TheAnalogKid83
A simple series RC circuit is considered a less accurate integrator or differentiator than an op-amp design due to its lower input impedance, which affects its performance under load. The high input impedance of op-amps allows them to operate more ideally, maintaining a low output impedance to drive subsequent stages effectively. In contrast, the RC circuit's integration constant can vary based on the load, leading to inaccuracies. The load impedance draws current from the output node, altering the frequency response and further diminishing accuracy. Thus, the buffering effect of op-amps significantly enhances the reliability of integration and differentiation in circuits.
TheAnalogKid83
Why is a simple series RC circuit considered a less accurate integrator/differentiator than an opamp design?
I know many real world reasons like stability, but the physics differential equations seem to derive into a perfect integrator or differentiator, so why are they not so perfect despite the mathematics?
Welcome to the PF, 83. The main difference is the very high input impedance of the opamp inputs. This let's the RC circuit operate more ideally, and still have the output signal be low impedance to drive the next stage (whatever that is). The "buffering" effect of the opamp (high input impedance, and reasonably low output impedance) is the difference.
alright, I figured it had something to do with buffers and driving a signal, which is basically anything to do with an opamp.
So an RC circuit's RC constant is going to change depending on its load, to where it's integration constant is not accurate?
Thanks for the explanation too.
Correct. When you write the KCL for the RC circuit, the load impedance draws a current out of the RC circuit's output node, right? That extra load term changes the frequency response.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
14K
