Interaction of hot gas with electrons
In summary, the interaction between the neutral hot gas molecules and the electrons will result in a non-uniform scattering of the electrons, with little to no significant distance traveled.
Stanley514
411
Lets say, we have a cathode that emits electrons into the space under
field emission and create a space charge in air.There is no arching of
electrons to anode.We have hot dense gas which blow on space charge
in certain direction.What would be the most likely outcome of interaction
between neutral hot gas molecules and electrons, which create a space charge?
For example,will be electrons blown away uniformly on macroscopic distance
or more likely they will not move for any remarkable distance at all or it will
be very non-uniform interaction?
The most likely outcome of the interaction between the electrons and the hot dense gas molecules would be that the electrons will be scattered in a non-uniform manner, due to the random motion of the gas molecules. The electrons may travel some distance, but it is unlikely that they will travel any significant distance before being scattered by another molecule.
Related to Interaction of hot gas with electrons
1. What is the interaction between hot gas and electrons?
The interaction between hot gas and electrons refers to the exchange of energy and momentum between these two entities. When hot gas, such as plasma, comes into contact with electrons, it can cause the electrons to gain or lose energy, which can then affect the behavior of the gas.
2. How does this interaction affect the behavior of hot gases?
The interaction of hot gas with electrons can result in various phenomena, such as heating or cooling of the gas, changes in the gas' density or velocity, and the creation of electromagnetic radiation. These effects can have significant impacts on the overall dynamics of hot gases in various environments, such as in stars or fusion reactors.
3. What factors influence the interaction between hot gas and electrons?
The strength of the interaction between hot gas and electrons depends on several factors, including the temperature and density of the gas, the speed and charge of the electrons, and the strength of the electric and magnetic fields present in the system.
4. Can this interaction be controlled or manipulated?
Yes, scientists can use various techniques to control or manipulate the interaction between hot gas and electrons. For example, in fusion reactors, powerful magnetic fields are used to confine and control the hot plasma, which is a gas of charged particles. Scientists also use lasers and other high-energy sources to excite and manipulate the electrons in the gas.
5. What are the practical applications of studying the interaction of hot gas with electrons?
Understanding the interaction between hot gas and electrons is crucial in many fields of science and technology. It is essential for developing advanced fusion reactors, studying the behavior of stars and other astrophysical objects, and designing advanced materials and technologies that rely on plasma and high-temperature gases.
  • Astronomy and Astrophysics
  • Quantum Physics
  • Electromagnetism
  • Atomic and Condensed Matter
