Interesting word problem posed
The discussion revolves around a complex word problem involving a cow tethered outside a barn, requiring the calculation of the grazing area accessible to the cow. The cow can graze in three-fourths of a circle with a 100-foot radius, while additional calculations are needed for the grazing area when tethered at different corners of the barn. The problem highlights the need to account for the barn's dimensions, which restrict the cow's grazing area, particularly when calculating the intersection points of the circular paths. Participants emphasize the importance of visualizing the problem through diagrams to accurately compute the areas involved. Ultimately, the problem is recognized as technically complicated, requiring careful consideration of geometry and symmetry.
twinhairdryer
So I had a student today ask me if I could come up with a simple 2 dimensional area problem. I was like -sure what is it. The question was:
If a cow were strapped to a tether outside a 10' by 10' square barn, at the corner of a small outlet door, and had a 100' leash/tether, what would the area be that he could cover to graze?
So the obvious is a circular sweep CCW with a 100 square foot keep out area in one direction, but then other? any ideas how to compute this one? thanks newbie
It not a 'simple' problem. It's a complicated problem. Not theory-complicated, just technical-complicated. You'll have to figure out the cow's path with the tether stretched to it's max CCW and CW. At some point they'll probably intersect. Then add up all the area of all the arc sectors making up the path up to that point of intersection.
It's best to start by drawing a picture. Obviously the cow can graze in three-fourths of a circle of radius 100, the three quadrants not containing the barn. Now stretch the tether across the front of the barn. You can now think of the cow as tethered at the other corner and the tether is now 100-10= 90 feet long. The cow can graze in one-fourth of a circle of radius 90. Now move to the third corner. The tether is now 90- 10= 80 feet long but you've already included a portion of this quadrant in your first three-quarters of a circle. The "new" grass is the portion of a circle of radius 80 "behind" the barn: between the lines formed by the sides of the barns extended. That is equal to the area bounded by the lines x= 0, x= 10, y= 0 and the curve x2+ y2= 802.
Added in edit: oops. Just as Dick said, if the cow goes around the barn the other way, she will pick up a little bit more grass symmetric to that last part. Because it is symmetric do this: find the area bounded by the lines x= 0, x= 5, y= 0 and x2+ y2= 80[/sup]2[/sup] and double it to get both parts.
Wrong again! It is not symmetric. Going around the barn the other way, the cow only has to pass the side of the barn, not front and side. The point where the two circles meet in back will be the intersection of x2+ y2= 802 and (x-10)2+ y2= 902. And you will need to find the area bounded by x= 0, x= a, where a is the x coord on that intersection, y= 0 and x2+ y2= 802, find the area bounded by x= a, x= 10, y= 0 and (x- 10)2+ y2= 902, and add.
Actually, there is a usable symmetry. The path is symmetric across the diagonal connecting the corner of the barn the cow is tethered to and the opposite corner. That helps.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
