Is My Internal Combustion Engine Efficiency Too Low? A Table Analysis
The discussion centers on the calculation of internal combustion engine efficiency, with a user reporting an unusually low efficiency value of 0.2%. Clarifications are requested regarding the units used for time, fuel flow rate, and specific fuel consumption. It is highlighted that the user failed to convert the efficiency decimal to a percentage by multiplying by 100. The conversation emphasizes the importance of accurate unit conversion in efficiency calculations. The user acknowledges the oversight and thanks the contributor for the clarification.
MMCS
i am calculating the properties of an internal combustion engine, however, for efficiency i am getting a value of 0.2%.This seems too low to be correct. please see attached table of values and point out any figures that seem incorrect
thanks
What are your units of time, fuel flow rate and engine specific fuel consumption?
Time: Seconds
Fuel Flow Rate: kg/s
SFC: kg/kW/h
In calculating engine efficiency, did you multiply by 100 to convert a decimal to a percentage?
Likes 1 person
No i didn't, its always the obvious, Thanks SteamKing.
