Interpretation of the functional Z (in Zee).
center o bass
In Zee's book at page 12 in both editions he finds that he can write the amplitude
$$\langle q_f|e^{-iHT} |q_i\rangle = \int Dq(t) e^{iS} $$
where T is the time between emission at ##q_i## and observation at ##q_f##. He then states that we often define
$$Z = \langle 0 | e^{-iHT} |0 \rangle $$
And he observes that by inserting a complete set of states we can write
$$ Z = \int q_f \int q_i \langle 0 | q_f\rangle \langle q_f | e^{-iHT} |q_i\rangle \langle q_i |0 \rangle = int q_f \int q_i \psi_0^* (q_f) \psi_0 (q_i) \langle q_f | e^{-iHT} |q_i\rangle. $$
But then a few sentences down he writes
$$Z = \int Dq(t) e^{iS}. $$
Is there an error in Zee here or ##Z## as defined above actually equal to the path integral given by ##\langle q_f|e^{-iHT} |q_i\rangle##? If so, how does the integration over the ground state wavefunction vanish?
I don't see how are you coming to this conclusion.
Zee often leaves out details like this. He is presumably now defining Dq to include the integration over the ground-state wave function. For a more thorough explanation of how this works, see Srednicki's text.
If I remember right, Zee leaves out the crucial detail to introduce a little imaginary part to the Hamiltonian such that you get the vacuum-to-vacuum-transition amplitude, i.e., in the path integral contributions from all other states are exponentially damped out in the limit t_i \rightarrow -\infty and t_f \rightarrow \infty, where t_i and t_f are the initial and final time in the original path integral for the time-evolution kernel.
A very good treatment of this issue can be found, e.g., in
Bailin, Love, Gauge Theories
I did not mean "vanish" in the sense of becoming zero, but in the sense of disappearing from the expression :)
I thought a substitution t→it is done so as to give a proper meaning to the exponential
exp(iS),not to hamiltonian.
I understand that the world of interpretations of quantum mechanics is very complex, as experimental data hasn't completely falsified the main deterministic interpretations (such as Everett), vs non-deterministc ones, however, I read in online sources that Objective Collapse theories are being increasingly challenged. Does this mean that deterministic interpretations are more likely to be true? I always understood that the "collapse" or "measurement problem" was how we phrased the fact that...
I would like to know the validity of the following criticism of one of Zeilinger's latest papers https://doi.org/10.48550/arXiv.2507.07756 "violation of bell inequality with unentangled photons" The review is by Francis Villatoro, in Spanish, https://francis.naukas.com/2025/07/26/sin-entrelazamiento-no-se-pueden-incumplir-las-desigualdades-de-bell/ I will translate and summarize the criticism as follows: -It is true that a Bell inequality is violated, but not a CHSH inequality. The...
I keep reading throughout this forum from many members that the general motivation for finding a deeper explanation within QM, specifically with regards to quantum entanglement, is due to an inability to grasp reality based off of classical intuitions. On the other hand, if QM was truly incomplete, and there was a deeper explanation that we haven't grasped yet that would explain why particles tend to be correlated to each other seemingly instantly despite vast separated distances, then that...
