I Interpretations of phase space in Dynamical Systems Theory
In Dynamical Systems Theory, a point in phase space represents a unique state of a system, with no simultaneous existence in multiple states. The discussion explores whether phase spaces can also represent fields of values across different locations, suggesting a 1-to-1 mapping from phase space points to locations in another space. The dynamics are defined through transformations that evolve the state over time, raising questions about the mathematical soundness of this field interpretation. The conversation touches on classical mechanics, questioning if additional dimensions in phase space relate to the cotangent bundle of configuration space. The complexity of defining these mappings indicates a need for a more abstract understanding of space in this context.
Stephen Tashi
Homework Helper
Education Advisor
TL;DR Summary
Can some phase spaces be interpreted as fields as well as a set of non-simultaneous states of a single system?
In Dynamical Systems Theory, a point in phase space is interpreted as the state of some system and the system does not exist in two states simultaneously. Can some phase spaces be given an additional interpretation as describing a field of values at different locations that exist simultaenously in a different space?
If ##p## is a point in a phase space and ##p## is a vector or more complicated mathematical object then there can be cases where there exists a 1-to-1 mapping that maps ##p## to a location in some other space (e.g. 3D space or a general metric space). Denote that location by ##x(p)##. Denote the other information contained in ##p## by ##x^c(p)##.
Let the dynamics of a system be given by the set of transformations ##\mathbb{T}## and use the notation that ##T_{\Delta t} \in \mathbb{T}## is the transformation that transforms ##p## to a new state ##T_{\Delta t}(p)## after an interval of time ##\Delta T## passes.
To regard the phase space as a field, consider the values ##( x(p), x^c(p))## to give information about the values of a field at locations ##x(p)## at time ##t = 0##. At time ##\Delta t##, define the value at location ##x(p)## to be ##(x(p), x^c( T_{\Delta t}(p))##.
Is this a mathematically sound definition that describes a field changing in time?
Mathematics news on Phys.org
For classical mechanics, isn't ##x^c(p)## additional dimension of the phase space? Isn't it just additional dimensions to the cotangent bundle of configuration space?
The definition doesn't specify a unique way to define ##x(p)## and ##x^c(p)## in terms of the phase space used by classical mechanics.
A "natural" way to do this for the phase space of a single particle would be to let ##x(p)## be the 3-D position information in ##p## at time ##t=0## and let ##x^c(p)## be the remaining components of ##p##. However, for this to define a 1-to-1 mapping between a point ##p## and 3-D space, we can't have a phase space where the particle can be at the same location in 3-D space and have two possible states ##p_1, p_2## at that location. If such a thing is possible in a phase space, then finding spaces where ##x(p)## can defined will require an abstract viewpoint of what a space is.
I don't know because I haven't studied the physical interpretation of a "cotangent bundle".
Cotangent bundle is the phase space in mechanics.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
