Introducing LaTeX Math Typesetting
766 replies · 761K views
[tex] <br /> <br /> \begin{align}<br /> x& = y && \text{def}\\<br /> & = y+\textcolor{blue}{(y-y)} && \text{add \textcolor{blue}{zero}}\\<br /> & = 2y-y && \text {\textcolor{red}{algebra}}<br /> \end{align}<br /> <br /> [/tex]
very plain text, slightlyfanciertext, loud text
[itex] \]<br /> <br /> \begin{picture}(200,200)(0,0)\multiput(0,0)(40,10){5}{\line(1,4){40}}\multiput( 0,0)(10,40){5}{\line(4,1){160}}<br /> \put(0,0){\vector(1,4){170}}<br /> \put(50,50){\circle*{10}} <br /> <br /> <br /> <br /> \put(160,40){\framebox(80,40)[r]{ \textcolor{blue}{\bf \[ x_{Bob} \] } } }<br /> \put(40,160){\textcolor{yellow}{\dashbox(80,40)[t]{ \textcolor{red}{ \[ t_{Bob} \] } } }}<br /> <br /> \qbezier(100,100)(200,100)(200,200)<br /> \linethickness{8pt} <br /> \textcolor{green}{\qbezier(0,0)(0,100)(100,100)}<br /> \linethickness{1pt} <br /> \qbezier(0,0)(0,100)(100,100)<br /> <br /> \end{picture}<br /> \[<br /> <br /> [/itex]
[tex] \newcommand{\VARTEXT}[2][\scriptsize]{\left(\mbox{#1\begin{tabular}{c}#2\end{tabular}}\right)}<br /> <br /> <br /> <br /> \VARTEXT[\large]{net-work done \\ on the object }<br /> =<br /> \VARTEXT[\large]{change in \\ the kinetic energy \\ of the object }<br /> <br /> [/tex]
this is wisky40 I'm not sure about this, but I'm going to try to write something using
Latex...[tex]E=K\lambda\int_{-a}^a \frac{dx_1}{x_1+x_2+b}[/tex]
How do I make this look better
[tex] a_0 (t)[/tex]
where a0 is supposed to be a function of t and not a0 times t.
ExtravagentDreams,
It looks fine to me as it is... what do you think is wrong with it?
- Warren
[tex] a_0 (t) \partial a_0 = t^2 \partial t[/tex]
I don't know. I just think it could sometimes be difficult to read and understand if it is ment to be a multiplication or a function of this variable.
I wonder if it would be better to use these {}
such as
[tex] F_g \{s,t\} = ...[/tex]
Does that conflict with anything else? I don't think I have used any sets in this manner, then again there is much math I have still to see. But I think it would be a little more obvious that it isn't a set instead of it not being multiplication
[tex] F_g^{ \{s,t\} } = ...[/tex]
[tex] F_g^{ (s,t) } = ...[/tex]
[tex] F_g (s,t) = ...[/tex]
[tex] F_g \{s\} = ...[/tex]
[tex] F_g (s) = ...[/tex]
try a font size change
[tex] F_g \mbox{\Large (s,t)}[/tex]
[tex] F_g \mbox{\large (s,t)}[/tex]
[tex] F_g^{\mbox{\HUGE (s,t) }} = ...[/tex]
The parentheses are standard notation...
[itex]a_0 (t)[/itex] is a function, [itex]a_0 t[/itex] is a multiplication.
- Warren
I suppose that is a good point. Now I am having trouble getting the font size to work though
[tex]\mbox{\Huge a_0 t}[/tex]
[tex]\mbox{\LARGE a_0 t}[/tex]
[tex]\mbox{\Large a_0 t}[/tex]
[tex]\mbox{\large a_0 t}[/tex]
- Warren
All four of those a0t's are formatted to the same size on my screen.
EDIT: The sizes are fixed now.
If you overload your post with too much latex math writing? Will it come out as errors?
Since, I think I may be doing so. As I was trying to verify in my post how I implicitly differentiated this equation, I used a lot of Latex Math writing to show my work. Then I preview it and it comes out with unsuccessful results.
EDIT MESSAGE: Nevermind, I found a couple of errors in my latex math writing. I fixed them and it came out great.
[tex] v = A\sin(\omega t + \epsilon + \phi) <br /> + \sum[/tex]
[tex]k = \sqrt{\omega\kappa}[/tex]
Hello everybody!
Do you know how to write in Latex a big square cap with underlying text like formulas in display math style?
[tex]\frac{1}{2}sqrt5+1[/tex]
Tesing for 3.0.3 upgrade:
[tex]q^2[/tex]
- Warren
Just trying to figure out if there's anything in particular screwing things up:
blah blah blah [itex]xy=z[/itex] blah blah
Test 3.03:
[tex]a^2[/tex] and [tex]a^3[/tex]
- Warren
This is a test of the new latex hierarchy:
[tex]\vec v \cdot \vec u = 100[/tex]
- Warren
[tex]\vec v \cdot \vec u = 20[/tex]
Test
[itex] \mbox{\Huge \[<br /> e^{jz} = cosz + jsinz\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\left( {e^{jz} } \right)^\nu = e^{j\nu z} = cos\nu z + jsin\nu z<br /> \]}[/itex]
Testing...
Testing...
[itex] \newcommand{\uE}{\mathrm{e}}<br /> \newcommand{\uI}{\mathrm{i}}<br /> \uE^{\uI\pi}+1 = 0[/itex]
[itex] \newcommand{\uE}{\mathrm{e}}<br /> \newcommand{\uI}{\mathrm{i}}<br /> \uE^{\uI{}x} = \cos{}x+\uI\sin{}x[/itex]
:smile:
Testing 2
Testing . . .
QED Lagrangian Density
[itex] \newcommand{\uI}{\mathrm{i}}<br /> \newcommand{\commute}[2]{\left[{#1}\!<br /> \mathrel{\vphantom{{#1}},\vphantom{{#2}}<br /> \kern-\nulldelimiterspace}\!{#2}\right]}<br /> \newcommand{\anticommute}[2]{\left\{{#1}\!<br /> \mathrel{\vphantom{{#1}},\vphantom{{#2}}<br /> \kern-\nulldelimiterspace}\!{#2}\right\}}<br /> <br /> \begin{align*}<br /> \mathcal{L}_{\text{QED}}(x) =& -\frac{1}{4}F_{\mu\nu}(x)F^{\mu\nu}(x)-\frac{1}{4}\left(\commute{\overline{\psi}(x)\gamma^{\mu}}{\frac{\partial_\mu}{\uI}\psi(x)}-\commute{\frac{\partial_\mu}{\uI}\overline{\psi}(x)\gamma^{\mu}}{\psi(x)}\right) \\<br /> &\quad{} -\frac{1}{2}m_{0}\commute{\overline{\psi}(x)}{\psi(x)}+\frac{1}{4}e_{0}\anticommute{\commute{\overline{\psi}(x)\gamma_{\mu}}{\psi(x)}}{A^{\mu}(x)}<br /> \end{align*}[/itex]
:zzz:
Can you tell me how I can create a dvi file with images/pictures included ?
Thanks
