kent davidge said:
Thanks
@samalkhaiat,
1 - is ##\delta e^{-1} = (\partial e^{-1}/ \partial e) (\partial e / \partial \tau) \delta \tau##?
No, the variation symbol \delta is a
Lie derivative, i.e., it is a derivation
but not a differential. So \delta e^{-1} = \left( \frac{d}{d e} e^{-1} \right) \delta e , but (as we will see below), \delta e \neq \frac{d e}{d \tau} \delta \tau = \frac{d e}{d \tau} \epsilon (\tau) .
2 - are the form of the variations you give in the beggining of your post obtained by requiring invariance of the action?
Yes, you can show that the invariance of the action S[x , e] under the diffeomorphism \tau \to \bar{\tau} = \bar{\tau} (\tau) implies (and is implied by) the following:
1) The coordinates behave like scalar fields, i.e., x (\tau) \to \bar{x} (\bar{\tau}) = x (\tau). So, for the infinitesimal diffeomorphism \bar{\tau} = \tau + \epsilon (\tau), we have, to first order in \epsilon, \bar{x}(\tau) = x ( \tau - \epsilon ) = x (\tau ) - \epsilon (\tau) \ \frac{d}{d \tau}x(\tau) = x (\tau) - \epsilon (\tau) \dot{x} (\tau) . The variation (or the Lie derivative) \delta x (\tau) is defined by \delta x (\tau) \equiv \bar{x}(\tau) - x (\tau). This clearly leads to \delta x (\tau) = - \epsilon (\tau) \dot{x}(\tau).
2) The e (\tau) field behaves as scalar density[*]: e (\tau) \to \bar{e}(\bar{\tau}) = \left( \frac{d \bar{\tau}}{d \tau} \right)^{-1} e ( \tau ) . Again, infinitesimally, we have \bar{e} (\tau + \epsilon ) = \left( 1 + \frac{d \epsilon}{d \tau} \right)^{-1} e ( \tau ) . Expanding both sides to first order in \epsilon, we get \bar{e} (\tau) + \epsilon \ \frac{d}{d \tau} e ( \tau ) = \left( 1 - \frac{d \epsilon}{d \tau} \right) e ( \tau ) . Note that in the second term on the left hand side we replaced \bar{e}( \tau ) by e ( \tau ) which is allowed by our first order approximations. Indeed \epsilon \ \frac{d}{d \tau} \bar{e}( \tau ) = \epsilon \ \frac{d}{d \tau} e ( \tau ) + \mathcal{O} (\epsilon^{2}). So, as usual, the Lie derivative of e is given by \delta e (\tau) \equiv \bar{e}(\tau) - e (\tau) = - \epsilon (\tau) \ \frac{d}{d \tau} \bar{e} (\tau) - e (\tau) \ \frac{d}{d \tau} \epsilon (\tau) = - \frac{d}{d \tau} \left( \epsilon (\tau) e (\tau)\right) .
[*] Imagine a one-dimensional manifold with symmetric metric “tensor” g_{\tau \tau}(\tau). The square of distances on such manifold is given by ds^{2} = g_{\tau \tau} (\tau) \ d \tau d \tau , \ \ \Rightarrow \ \ ds = \sqrt{g_{\tau \tau}(\tau)} \ d \tau \equiv e (\tau) \ d \tau , where we have defined the (frame) field e (\tau) \equiv \sqrt{g_{\tau \tau}(\tau)} Now, the invariance of the distance ds = d \bar{s} under arbitrary general coordinate transformations \tau \to \bar{\tau} = \bar{\tau}(\tau), implies that the frame field e (\tau) transforms as scalar density: \bar{e}( \bar{\tau} ) \ d \bar{\tau} = e ( \tau ) \ d \tau \ \ \Rightarrow \ \ \bar{e}(\bar{\tau}) = \left( \frac{d \bar{\tau}}{d \tau} \right)^{-1} e ( \tau ) .
