Are the Fourier transforms of a function and its inverse related?
The discussion explores the relationship between the Fourier transform of a function and its inverse. It suggests that while a one-to-one function uniquely determines its inverse, there is no straightforward formula connecting their Fourier transforms. The participants agree that the transforms are related through this indirect relationship, but the interaction of the Fourier transform with function composition is complex. Ultimately, no simple or direct relationship exists between the Fourier transforms of a function and its inverse. The topic highlights the intricacies of Fourier analysis in relation to function inverses.
john1989
Hi
Does anyone know if there is a relation between the Fourier transform of a function and the Fourier transform of the inverse function
in summary
FT[f(x)] ?= FT[f-1(x)]
Thanks!
Mathematics news on Phys.org
Logically they must be related because a 1-1 function uniquely determines its own inverse. Therefore, the Fourier transforms are at least related through this indirect relationship. However, I don't think there is any reasonable formula to relate the two. The Fourier transform does not interact with composition of functions in a simple way.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
