How Do You Transform and Simplify the Inverse Laplace Function 1/[s(2s^2+2s+1)]?
fern518
Hey everyone.
I've got through most of a problem that involves finding an inverse laplace transform, but I am stuck at one part that requires algebraic manipulation. The function is
1/[s(2s2+2s+1)]
So far I have modified it too look like .5/[s(s+.5)2 +.52](1/.5)
I'm not sure how to modify the function with that extra s in the denominator.
I had seen that the function could be transformed into (1/s) - [(s+.5)+.5]/[(s+.5)2+.52 and then from that the inverse Laplace could be easily obtained, but I am not sure how this transformation was done. I am sure there is a property I'm not thinking of, but any help on this would be greatly appreciated!
You can consider like this
<br /> \frac{1}{s(s+a)^2}=\frac{A}{s}+\frac{Bs+C}{(s+a)^2}<br />
From the above equation find A, B and C values by substituting different values of s.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
