What is the correct method for calculating the co factor of a 3 x 3 matrix?
  • Thread starter Thread starter Rob K
    Inverse Matrix
To calculate the cofactor of a 3x3 matrix, it's essential to apply the correct sign based on the position of the element. The sign is determined by the formula (-1)^(i+j), where i and j are the row and column indices, respectively. For the specific element in question, if the sum of the indices is odd, the cofactor will be negative. The calculation of the determinant for the cofactor should be checked to ensure accuracy, as discrepancies may arise from miscounting indices or signs. Clarifying whether the cofactor expansion is along a specific row or column can also help resolve confusion.
Rob K
This is insane, I am trying to revise the inverse of matrices and this one element is being really stubborn, please help.
Here is the matrix
3 -1 7
2 0 1
5 -2 6
I have transposed it
3 2 5
-1 0 -2
7 1 6
Now as for replacing the element of the co factors, I am stuck on the second one on the first row.
I have calculated the co factor to be as follows:
(-1 * 6) - (-2 * 7) = 8
fine
but now you times it by the place sign, which is a minus is it not?
So this gives me -8
the book disagrees
And to my horror so does Matlab.
Where am I going wrong?
An help would be appreciated, as I simply can't see where I am going wrong.
Kind regards
Rob
Let me clarify first, are you trying to find the co-factor expansion along a specific column or row? If so, which one is it? Recall that the co-factor expansion formula requires any position where the sum of the row index and column index being odd to be of negative sign (Ex: Suppose your matrix is A, A1,2 has a negative because 1+2=3 which is odd).
Are you taking the determinant to check whether the matrix is indeed invertible?
Start at the upper left of the matrix, count, starting with "0" as the first element, across the row to the correct column, then count down to the element you want. The sign is (-1)^n where "n" is the final count.
Alternatively, and perhaps simpler, is to say "plus" at the upper left and go across and down alternating "minus" and "plus" at each element.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
