How Can I Take the Inverse of an Image Matrix in MATLAB?
The discussion revolves around the attempt to invert an image matrix using MATLAB, specifically with the commands A=imread('noise.jpg') and inv(A). The user encounters an error indicating that the 'inv' function is undefined for 'uint8' input arguments. The conversation clarifies that imread returns an array of 8-bit unsigned integers, while the inv function requires a square matrix of double-precision floating-point numbers. The solution provided suggests converting the image matrix to double precision using inv(double(A)). Additionally, there is some confusion about the purpose of inverting an image matrix, with participants questioning the rationale behind this operation.
Az83
I'm trying to take the inverse of an image matrix by doing the following:
>> A=imread ('noise.jpg');
>> inv(A)
But I'm getting the following error:
? Undefined function or method 'inv' for input arguments of type 'uint8'.
How can I change the image matrix so that I can take the inverse of it?
Technology news on Phys.org
Erm what?! hah
well what lanagauge is that?! Matlab?
maby try inv('noise.jpg') :S
hmmm i duno not sure would be easier to know what language your doing it in and what functions or methods you have available.
If this is C++, you must be using some non-standard add-on library. imread() and inv() are not standard C++ functions, as far as I know.
>> inv(A)
I recognise this as MATLAB. It would have helped if you had said so.
imread() takes an image file and returns an N x M x 3 array of 8-bit unsigned integers. inv() expects an N x N array of floating points.
I have to ask why would you want to invert an image array? I don't understand the point.
I also don't understand why you'd want the matrix inverse of an image, but you can use this:
inv(double(A))
You just need to convert the array to the double-precision floating-point datatype before inv() will know what to do with it.
- Warren
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
