What is the solution for an inverse third order equation when solving for X?
  • Thread starter Thread starter cooka111
    Inverse
To solve the inverse third order equation for X, start by multiplying the equation y = y_{0} + (a/x) + (b/x^2) + (c/x^3) by x^3 to eliminate the denominators. This transforms the equation into a cubic polynomial of degree three. The roots of this polynomial can be found using Cardano's method, which is a standard approach for solving cubic equations. The discussion highlights the importance of maintaining the integrity of the data when swapping axes, as it can significantly affect the R² value. Understanding these steps is crucial for independently calculating both Y and X values.
cooka111
I have a question about solving a formula.
I have a set of data which I have fit to an inverse third order equation, if I swap the axes (use X as Y and vise versa), R2 suffers dramatically but I would like to calculate both Y and X values independantly. I am wondering what the solution for the following equation is when cast to calculate X. My algebra is a little rusty and I am not sure where to start.
y = y_{0}+\frac{a}{x}+\frac{b}{x^{2}}+\frac{c}{x^{3}}
Assuming I have values for a,b,c, and yo, how do I solve this for x?
Mathematics news on Phys.org
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
