Invert Battery and Maintaining Low Noise
  • Thread starter Thread starter dmorris619
    Battery Noise
The discussion revolves around the challenge of inverting the output of a battery to create a dual power supply for an operational amplifier, specifically focusing on maintaining low noise levels in the circuit design. Participants explore various methods for achieving this inversion while minimizing noise, which is critical due to the low voltage signals involved.
  • One participant suggests using two batteries as the lowest noise solution, questioning if that is feasible.
  • Another participant recommends inverting the voltage and then post-regulating with a low-dropout linear regulator to reduce noise.
  • A participant with experience in low noise analog circuits shares a method involving an external power supply with an inverted rail, followed by regulation and filtering.
  • There is a suggestion to use an inverter with a high switching frequency (at least 500KHz) followed by two linear regulators to mitigate noise.
  • Concerns are raised about the use of large capacitors due to the device's operational constraints, with a proposal to consider LC filters instead.
  • One participant expresses interest in using inductors and asks for suggestions on inverters with high switching frequencies, while also considering the implications of capacitor discharge on battery life.
  • A later reply identifies the LTC1550CGN inverter as a potential solution, discussing its specifications and the proposed method of using a voltage divider for output adjustment.
Participants present multiple competing views on the best approach to achieve low noise in the circuit design. There is no consensus on a single solution, as various methods and components are proposed and debated.
Participants mention limitations regarding the size of capacitors and the need for quick turn-on times, which may affect the feasibility of certain solutions. The discussion also highlights the importance of maintaining low noise levels due to the sensitivity of the signals involved.
dmorris619
I am trying to invert the the output of a battery so I can run an op-amp double ended with 5 volts and -5 volts. The battery itself produces 7.5 volts so I am passing it through a linear regulator to drop it down to 5 volts with low noise, at the expense of heat/efficiency. This is all great until I try to invert the voltage from the battery for the other rail, I want to pass that through ICL7660CPA which will invert the signal, but I am afraid that by using this I will put too much noise on the rail even if I pass it through the regulator and use large decoupling capacitors.
To give some perspective on why low noise is so important in this design is because our input to the double ended op-amp is on the scale of microvolts and our output will be on the scale of millivolts. To add to that a small fluctuation will give results that are not accurate enough, so we are trying to minimize noise from the device as much as possible. We also cannot use capacitors that are very large because the device will be repeatedly turning on and off and the charge time required could prove to be a problem.
Thus I am looking to see if anyone can provide two things, an explanation of just how the inverter proposed above works and if there is another less noisy alternative (other than a second battery) to the proposed inverter.
Thanks in advance
Thanks in advance
Well, the lowest noise solution would be to use two batteries. Is that an option?
If not, definitely invert and post-regulate with a linear regulator. I'd recommend using a low-dropout regulator, so it has a good Vin-Vout difference.
I work a lot with low noise analog circuits for very sensitive instrumentation. A lot of my projects involve working with femptoamp currents and nanovolt potentials and I run into your problem a lot. Usually the way I get around it is by using an external power supply that has an inverted rail, maybe at -15V, regulate it to -12V, follow that with an LC filter, regulate it again to what ever voltage I need, then follow with another LC filter.
In your case I would probably look at using an inverter with a very high switching frequency, as high as possible. Like 500KHz, minimum. I would then follow that with two LDOs in series. Even 79XX's are pretty good at cutting out noise but won't like large low frequency transients. You said that you can't use large caps but what about an LC filter? Do you have any room/budget for some inductors?
I think this design could work, the only difference is that I will be working with batteries rather than a power supply. I could definitely put in some inductors provided they are not excessive large. I apologize for using such vague terms as excessively but as of right now I don't know what the turn on time of my device has to be. So let's say I want my turn on time to be around 2mSec and go from there.
Could you possibly suggest some inverters that have a high switching frequency? Also would the LDO's regulate to the same voltage or would they drop the voltage in stages? I definitely have room to place large capacitors and inductors on my board to help smooth things out but I am not sure I have the time required because in order to preserve battery life we will be turning everything but the microprocessor off and then turning everything back on, I just remembered that capacitors store their charge even when not connected to a voltage source, so maybe large capacitors can be used provided I find a way to keep them from discharging.
So I think I found an inverter that fits my needs, its the LTC1550CGN inverter. It has an input between 4.5 and 6.5, so I'll have to run the battery through a positive regulator first and then through this. It says that the output is adjustable in the 16pin model by attaching a voltage divider to the IC. Do you guys think this is a good choice for an inverter following the method of regulating it to 5 volts, then inverting it with a voltage divider attached to increase it to 5 volts at the output and then putting it through a series of regulators to smooth out the output?
  • · Replies 21 ·
  • · Replies 88 ·
12K
