Solve Inverse Z-Transform for H(z)=1/(1-2/3*z-1)
  • Thread starter Thread starter Drao92
    Z-transform
Drao92
H(z)=1/(1-2/3*z-1)
h(n)=?
I tried to use the residue method to solve this problem but it doesn't give me the good result and i am not sure if i don't know how to use the method or this problem can't be solved using this method.
Also, its pretty obvious that the result is h(n)=(2/3)n because it looks like a geometric progression
I used the formula of residue method.
h(n)=residue(H(z)*zn-1) when z=2/3
The result is 3*(2/3)n
Its this result wrong because when we calculate Z transform of (2/3)n which is (1-(2/3)n*z-n )/(1-(2/3)*z-1) we ignore (2/3)n because is 0 when n=infinity?
Drao92 said:
H(z)=1/(1-2/3*z-1)
h(n)=?
You have
$$z^{n-1} H(z) = \frac{z^{n-1}}{1-\frac{2}{3z}} = \frac{z^n}{z-\frac{2}{3}}.$$ How did you get ##h(n)=3(2/3)^n## from that?
Likes 1 person
I think i found what what I am doing wrong.
I made H(z)=3z/(3z-2) then i multiply by zn-1 and simplify by (3z-2) but i must simplify by (3z-2)/3 when calculating the residue... From now ill stick only to z-x form for denominator.
Eveyrthing is clear now, thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
