IR and UV absorption of materials
Materials with good absorbance at 808nm, 365nm, and 404nm are sought for applications involving remote heating of gels. Carbon black is suggested as a suitable option for all three wavelengths. The optical properties of powders differ significantly from bulk materials, affecting their absorbance characteristics. Resources like RefractiveIndex.info may not provide direct absorption spectra, but transmissive spectra can be utilized with adjustments for reflection. Rare Earth compounds are recommended for those seeking sharp absorption lines.
daidalos1000
Hello all,
I am looking for easy to obtain materials, preferably in powder form, with good absorbance at 808nm, 365 nm and 404 nm each (either one material for each wavelength or one for all three).However I can't seem to find absorbance charts. Does anyone have any idea either on which material to use or on the whereabouts of a good collection of absorbance charts?
Best Regards,
George
The optical properties of a powder can be much different than a homogenous bulk sample- for example, a sheet of glass is transparent, but glass powder (or ground glass surfaces) are highly scattering.
you may find some useful information here: http://refractiveindex.info/
What is your application?
Carbon black (soot) is pretty good at all of these wavelengths.
@ Andy
Thank you for your reply. I am aware of that, I just thought I would choose the material that comes first amongst others in my spec AND can be acquired in powder form. RefractiveIndex doesn't cite absorption spectra as far as I know. I thought I could use transmissive spectra in a reverse manner if I can acount for reflection. My application is to remotely heat up a gel using one of these wavelengths and I need to the powder to make sure the beam is absorbed.
@UltrafastPED thank you, I will try that.
If you are after sharp absorption lines, you should have a look at the absorption spectra of rare Earth compounds.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
