Is a Universe with Just One Point Charge Physically Meaningful?
The discussion centers on the concept of a universe with a single point charge and whether physical laws, fields, and energy are meaningful in such a scenario. Participants debate the validity of defining fields and forces without other charges present, questioning if motion and force can exist in isolation. While some assert that fields and energy are defined even in a vacuum, others argue that without interactions, these concepts lose significance. The conversation highlights the limitations of scientific inquiry in hypothetical scenarios, emphasizing that such discussions may not yield testable conclusions. Ultimately, the discourse reflects on the philosophical implications of defining physical phenomena in an empty universe.
Altair Tans
What if there is a universe with just one point charge in existence....just a charge with vast emptiness around it....now here all laws of physics remain same...
But is the concept of field and energy defined there??
Who cares about such a universe? It isn’t this one and we don’t have access to it to test any claims about it. Any statements you might make about it are not scientific.
If all laws of physics are the same then clearly fields and energy are defined.
By the way, the excessive use of periods is obnoxious. If your keyboard is sticky then clean it, otherwise just stop.
Hi, there are actually plenty of problems I had to do regarding this in my electromagnetism class. If you look at calculations involving Gaussian surfaces as well as coulomb'a law it should answer your question.
Aren't fields defined in terms of forces acting on a test charge, and how is that possible if there are no other charges?
Likes Altair Tans
In vacuum there are no charges, but there are fields. Your definition is a little wrong.
What are fields there for then?
I am speaking in the sense that like if there's just one object in an empty universe its motion is not defined. Its moving or at rest is not defined as long as there's no frame to refer with.
Similarly i believe without something to act upon the concept of force , field of force and energy associated with the force are all invalid.
Am i wrong somewhere?
What do you think? What things are associated with the fields that might cause problems if they didn’t exist in vacuum?
You stipulated a one-charge universe where all laws of physics remain the same as ours. There is a charge so by Gauss’ law there is a field
Ok so there is a field, there is energy associated with it, but these quantities don't get a chance to be in use.
Is my understanding correct sir?
How can we possibly know if your understanding of single charge universes is correct? I have no evidence to contradict your claims and you have no evidence to support them. There is no possibility to use the scientific method to answer such questions.
As @Dale says. This is a "tree falls in the forest" situation. Does it make a sound? It doesn't matter. Pick whichever answer yields a simpler theory.
