Is air resistance dependent on mass?
7 replies · 5K views
quietrain
thanks!
The air resistance is a force that is imposed on whatever comes air with some relative velocity regardless of their mass. A styrofoam ball undergoes the same air resistance that a lead sphere of the same diameter.
It depends on the situation.
If you increase the mass/weight of an aircraft (by filling it with more passengers) then the lift required to keep it in the air increases. The wing has to fly at a larger angle of attack to produce the extra lift and that increases drag.
Changing the wing profile is an alteration to the shape.
alright thanks peeps!
If you drop two objects (identical except for the mass) from a height initially the acceleration is the same (when the speed = 0) but as air drag takes a role (as the speed comes into play) the greater mass will always have a greater acceleration than the lesser mass as well as a higher terminal velocity
