Is aluminum foil more electrically conductive on the shiny side?
  • Thread starter Cash Fulton
  • Tags
    Aluminum
In summary, the shiny side of aluminum foil is more electrically conductive due to its smooth surface and lower amount of oxide buildup. This makes it a better choice for electrical contacts, despite the potential interference from the oxide layer.
Cash Fulton
24
Is aluminum foil more electrically conductive on the shiny side or the foggier not-so-shiny side?
I assume you mean, "On which side would electrical contacts to the foil have lower resistance?" The conductivity is through the bulk of the material (ignoring high-frequency skin effects, etc).
You would get better contact to the shiny side. The shiny side is shiny because it is smooth. The not-so-shiny side will be found to be much rougher at the microscopic level. This also affects the surface area at the microscopic level and, as a result, the amount of oxide that spontaneously forms. Even if your contacts have enough pressure to "squish out" the roughness, that oxide will still get in the way and degrade the contact conductivity.
Why is Aluminum Foil Shiny on One Side But Not the Other?
Likes Cash Fulton, meBigGuy, dlgoff and 1 other person
The oxide layer on aluminium is notorious for interfering with electrical contacts, shinny side or not. Aluminium is sometimes a poor conductor choice for this reason. OTOH it is cheap, lightweight, and a good conductor, so it is often worth the trouble.
Likes Cash Fulton
Thank you, everyone.
1. Is aluminum foil more electrically conductive on the shiny side?
The answer to this question is no. Both sides of aluminum foil have the same level of conductivity. The shiny side is created during the manufacturing process and does not affect the foil's conductivity in any way.
2. Why does one side of aluminum foil appear shiny and the other side dull?
The shiny appearance on one side of aluminum foil is created when the foil is pressed between rollers during the manufacturing process. This process produces a smoother and shinier surface on one side of the foil, while the other side remains dull.
3. Does the thickness of aluminum foil affect its conductivity?
Yes, the thickness of aluminum foil does affect its conductivity. Thicker foils have lower conductivity compared to thinner foils. This is because thicker foils have more resistance to the flow of electricity.
4. Can I use aluminum foil as a conductor for electricity?
Yes, aluminum foil can be used as a conductor for electricity. It is a good conductor because it is made of metal and has a low resistance to the flow of electricity. However, it should not be used as a permanent or long-term electrical wiring solution.
5. Is aluminum foil a good choice for shielding against electromagnetic interference (EMI)?
Yes, aluminum foil can be effective in shielding against EMI. Its conductive properties allow it to absorb and redirect electromagnetic waves, preventing interference with electronic devices. However, it is important to use a sufficient amount of foil and properly ground it to be effective.
  • Thermodynamics
  • Electrical Engineering
  • DIY Projects
