Is MWI Compatible with a Deterministic Interpretation of Decoherence?
  • Thread starter kof9595995
  • Tags
    Decoherence
In summary, decoherence is a deterministic process that explains how quantum probabilities evolve towards classical ones on a macroscopic level. It is not an interpretation of QM, but an experimental fact. Although it plays a role in some interpretations, it does not fully explain measurements as it cannot determine which possibility the system will end up in. It may need to be supplemented with a many-world interpretation in order to fully explain measurements.
kof9595995
679
Just read a bit about decoherence from wiki, it seems to me that according to this interpretation, the probabilistic nature of QM is no different from statistical mechanics, and the irreversibility of measurement is just thermodynamic, so does this mean decoherence is indeed a deterministic interpretation?
First of all, decoherence is not an interpretation, but an experimental fact. Theoretically, it is a direct consequence of the Schrodinger equation applied to a large number of degrees of freedom.
Decoherence is a deterministic process, in which probability evolves deterministically. In this process quantum probabilistic laws effectively evolve towards classical ones, thus explaining why, on the macroscopic level, for all practical purposes we can use classical statistical mechanics. More precisely, decoherence provides a continuous deterministic mechanism by which the interference terms in the probability density become dynamically suppressed.
Decoherence also plays an important role in some interpretations of QM, especially many-world and Bohmian. But these interpretations (controversial just as all other interpretations) should be distinguished from decoherence itself which is not controversial at all.
Is it correct to say interpretations of QM are mainly concerned with measurements? So does it mean decoherence is not the whole story of measurements? If so, what cannot be explained by decoherence? Sorry for shooting a lot of questions at the same time : )
It's deterministic in what sense? The interference terms do get suppressed by known procedures making a, initially pure, state mixed. But decoherence cannot tell you the specific state that the system will end up to. Right?
Right. It is a deterministic evolution of the probability density, so probabilistic interpretation is not removed (unless you adopt a many-world or Bohmian interpretation).
Yes.
kof9595995 said:
I
True.
Why and how the system takes only one of the possibilities (defined by the decohered density matrix).
Thanks.
need be supplemented with MWI.
to takes only one of the possibilities.
1. What is decoherence?
Decoherence is a process in quantum mechanics where a system becomes entangled with its environment, causing it to lose its quantum properties and behave like a classical system.
2. Is decoherence a deterministic process?
Yes, decoherence is considered to be a deterministic process. This means that the outcome of the process can be predicted with certainty based on the initial conditions of the system and the laws of physics.
3. How does decoherence affect quantum systems?
Decoherence causes quantum systems to lose their quantum properties, such as superposition and entanglement, and behave more like classical systems. This can make it difficult to observe and manipulate quantum effects.
4. Can decoherence be reversed?
No, decoherence is an irreversible process. Once a system becomes entangled with its environment, it is difficult to isolate it and reverse the effects of decoherence.
5. How does decoherence relate to the measurement problem in quantum mechanics?
Decoherence is one proposed explanation for the measurement problem in quantum mechanics. It suggests that the apparent randomness and collapse of the wave function upon measurement is a result of the system becoming entangled with the measuring apparatus, rather than a fundamental property of quantum systems.
  • Quantum Interpretations and Foundations
  • Quantum Physics
