Is Earth's Gravitational Field Zero at 900km Altitude?
Astronauts in a space capsule at 900km altitude do not experience weightlessness due to a lack of gravitational force; rather, they are in free fall while orbiting Earth. This means there is still a gravitational field present, but the sensation of weightlessness occurs because both the astronauts and the capsule are accelerating at the same rate towards Earth. The discussion emphasizes the importance of understanding circular motion and net forces in this context. It also highlights that weightlessness does not equate to zero gravity, as demonstrated by other scenarios like parabolic flight. The thread concludes with a reminder to adhere to posting guidelines.
samaank
? Earth's Gravitational Field
Hi, i have a physics question in my physics portfolio, it goes as follows
Critically assess the following statement: ‘Astronauts in a space capsule orbiting the Earth at a height of 900km experience weightlessness: hence the gravitational field due to the Earth must be zero at that altitude'. Include calculations in your answer.
Can someone please help ?
i don't know what to calculate
Think about this for a minute. If you are moving in a circular motion (which we will approximate the orbit to be), is there any acceleration on the capsule+astronauts system? If there is, there's a net force applied to that system. If there's no net force or acceleration, you'd have Newton's First Law. Is that what you have in this situation?
Once you figure that out, THEN you can start to try to explain why the astronauts experience weightlessness, which will lead to the conclusion that "weightlessness" does not mean zero gravitational force (example: astronauts training in the "vomit" plane).
Zz.
I just realized that you posted this in more than one location. Please do not do that! Spend some time reading our Guidelines before posting.
This thread is closed.
Zz.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
