We may assume f and f' are continuous, since that is not the main question I am concerned with.
HallsofIvy said:
Saying that
\lim_{x\to a} f(x)= F
is exactly the same as saying
\lim_{n\to\infty} f(x_n)= F
where
\lim_{n\to\infty} x_n= a
so, yes, your equation is correct.
It is not quite the same thing, since that is not how the derivative is defined - all definitions I've seen have one value fixed. I.e. just plugging in x_n to f'(x) does not give the same function as I described, so sequential characterization doesn't work directly:
f'(x_n) = \lim_{x \rightarrow x_n} \frac{f(x) - f(x_n)}{x-x_n}
or we could define it as
f'(x) = \lim_{n \rightarrow \infty} \frac{f(x) - f(x_n)}{x-x_n}
However neither of these are the same as the limit I gave, in which both x_n and x_{n-1} are changing sequences, and aren't fixed. Even if accepted as another definition, then can you offer a proof the definitions are equivalent?The problem I was stuck with when I tried to use something like
to get a bound, is that then any delta requirement depends on the specific value of n, but I may need to choose n large enough so that x_n and x_{n-1} meet the delta requirement, but that ends up potentially changing x_n and the delta needed again since it depends on the specific x_n, so it's sort of like a race condition.
