Is Infinity Truly Limitless or Does It Have Boundaries?
  • Level: Undergrad
  • Thread starter Skhandelwal
    Infinity
143 replies · 23K views · last reply
I didn't know that there are types of infinites in mathematics. Would you mind telling what they are? Btw, I was wondering, Is it possible for there to be hypotenuse infinitely long of two infinitely long rays? Like on the cartesian coordinate x-y. x and y are the rays starting from 0 to positive infinity.
There's some discussion on the first page. You may find MathWorld's brief pages useful:
http://mathworld.wolfram.com/Infinity.html
http://mathworld.wolfram.com/Aleph-0.html
http://mathworld.wolfram.com/Continuum.html
and for the ordinals
http://mathworld.wolfram.com/OrdinalNumber.html
http://mathworld.wolfram.com/TransfiniteNumber.html
As you'll undoubtedly find out if you spend some time sifting through the mathworld pages linked to those Greathouse gave, there are infinitely many 'sizes of infinity.'
To be clear:
Two sets have the same cardinality (the same "size") if and only if there exists a bijection (an invertible function) between them. The sets (0,1) and (0,2) have the same cardinality because x -> x/2 is a bijection between (0,2) and (0,1).
The integers do not have the same cardinality as the real numbers (the real numbers have larger cardinality). This is because there is no bijection between them, as can be shown using Cantor's diagonal argument, for example. There is, however, a surjection from the reals to the integers (a function with the reals as the domain and the integers as the range), which is why the reals have larger cardinality.
Given any set S, it can be shown that the "power set" of S, defined as the set of all subsets of S and denoted by [itex]2^S[/itex], has greater cardinality than S; that is there is a surjection, but no bijection, between [itex]2^S[/itex] and S. That's why there are infinitely many 'sizes of infinity.'
Your question about an 'infinite hypotenuse' doesn't make any sense~
To answer the original question without all the hoo-hah...I believe that it was put to me as simply "infinity is a way to describe the behavior of certain sequence of numbers". Thus it should not be thought of as a number such as 1 or 2. I hope this is sufficient for generally grasping the concept without bringing into light extended real number lines.
Unfortunately, the word "infinity" is used in a variety of (related) ways in different fields of mathematics. What you are talking about is one of them. The idea of "cardinality" is another. In topology, we can, for example,add a "+ infinity" and "- infinity" to the real line (the "Stone-Cech compactification"), making it topologically equivalent to a closed interval. Or we could just add a single "infinity" (the "one point compactification), making it equivalent to a circle.
That's the extended reals. The Stone-Cech compactification adds a whole bunch of new points; it's not a very pretty space.
Skhandelwal said:
is speed of light infinity in terms of velocity?
The speed of light is about 3x108 m/s, which is less than infinity. But you can think of Newtonian mechanics as the limit of relativistic mechanics as c->infinity. Since c is very large by everyday standards, this isn't a bad approximation.
I am sorry, I should have been more specific, is speed of light infinity by standards of velocity for weight objects?
"by the standards" of objects with non-zero rest mass, the speed of light is simply a speed that can't be reached. As it is approached, the mass of the object increases so that it takes more work to accelerate it more, and no amount of work can get it up to c. But the speed is just the number I gave above.
The speed of light isn't infinite. For example, it takes light about eight minutes to get from the sun to the earth.
It is true that you can't accelerate massive objects to or past the speed of light, because as speed approaches the speed of light, the required kinetic energy increases without bound (ie. to infinity).
The kinetic energy and mass as v --> c both approach infinity, so in a sense yes. In the literal sense, c is quite finite.
No, it is a number about 3x10^8ms^-1. That is not even a big number, never mind 'infinity' (please, let us know what you are using infinity to mean, since for everyone else it is something to do with 'not finite').
Btw, one of you said few post ago that we pretty much understand infinity, well, if that is so then how do explain cantor's paradox?
Eeh, what do you mean now?
Whenever someone introduces a new term like this, it is wise to look it up on google before asking, but then again, I am the one to be blaim b/c I shouldn't expect everyone to look it up. Here is the link: http://en.wikipedia.org/wiki/Cantor's_paradox
Well, the answer is given in the link you provided:
Like many mathematical "paradoxes" it is not actually contradictory but merely indicative of a mistaken intuition, in this case about the nature of infinity and the notion of a set. Put another way, it is paradoxical within the confines of naïve set theory and therefore demonstrates that this theory is insufficient for the needs of mathematics. The fact that NBG set theory resolves the paradox is therefore a point in its favor as a suitable replacement.
Yes, and what is the problem there? I don't see it is either paradoxical or in anyway shows that the definition "something is infinite if it is not finite" is at all not well understood.
What's to explain? It just says that there is no largest cardinal infinity. Is there something you don't understand about it?
It is a paradox, that means that it is not understood. Nevermind, that wasn't my point. Since you guys understand infinity, I was hoping if you could clear my questions about it.
1. What does it mean when one reaches infinity faster than the other?(ex. y=x^3 graph compared to y=x^2.
2. For objects that have mass, is reaching the speed of light infinity? If it is then that means infinity have their limits. Just like infinite sum. But wouldn't that mean that infinities aren't really infinity, they are just infinity in their own way? Like whenever you take steps, and decided to take half the step you took before and so on, you will be never get where you want to go. meaning not that you can't go, but not in the way you want to. Am I right?
3. Is infinity times 0=0 for sure or it depends?(are there any exceptions?)
4. Why doesn't one infinity=another?
5. As the parabola y=x^2 increases, if you take the slope of the secant line from its origin to some point. And then if you pick a farther point, slope increases, and then it keeps increasing, well, if you get to infinity, will the slope be undefined? If it would then how would y=x^2 be a function? Because it would fail the vertical line test.
Oh heck, I should post the problem I am having understanding cantor's paradox. As far as I understand, it states that there is one set which consists of all the infinites(the amount of them is infinite by itself) and this set is greater than all of those infinities. Well, how can it be greater than all of them if that set itself is in it?(since all the infinities are in it)
1. If lim f(x) = infinity and lim g(x) = infinity, then f(x) reaches infinity 'faster' when lim f(x)/g(x) > 1.
2. No, the speed of light is not infinite.
3. Infinity times zero is undefined.
4. Different infinities can be of different sizes, just like finite quantities can be of different sizes. This is a philosophical question, not a mathematical one.
5. The slope increases without bound. The limit of the slope is infinite. f(x)=x^2 is a function in the reals and the exteded reals; it passes the vertical line test in the extended reals because f(infinity) = infinity and f(infinity) is not equal to any finite value.
You misunderstand Cantor's paradox. There is no 'set of all sets'; no set contains all sets. There is a proper class of all sets, but as a proper class it need not contain itself (since it isn't a set). There are other set theoretical foundations which solve this differently; type theory is an example. I'm not well informed about type theory, though; you'd haveto ask someone else.
1. I know that but since infinity can't be reached, does it really matter if you are faster or slower?
2. How do you figure that?
3. So what would be a mathematical answer?
4. Does that mean that even though y=x^2 always reaches infinity, it never gets there, b/c if it would, it wouldn't be a func. anymore?
Can someone explain cantor's paradox to me? I thought I had it figured out.
Yes, because knowing that the functions limit as I described tells you things about their behavior in the finite realm. For any N, there exists m such that for any x > m, f(x) > N * g(x) or something like that.
:confused: The speed of light is less than, say, 10^100 m/s, which is still quite finite.
How about this: at infinite speed travel time would be 0 for any finite distance, but this is not the case for light. It still takes, say, 8 minutes to get from the sun to the earth.
"Undefined", just like 0/0.
You'll have to rewrite this in a sensible manner before I'll be able to answer. f(x)=x^2 is never infinite for finite x, but it's infinite for infinite x. f is closed in the reals and closed in the extended reals, though.
What do you not understand?
3. I thought #/0 is undefined and 0/0 is undeterminate.
4. What I mean is that if you keep taking secant line from the origin of the function to a farther and farther point, the slope keeps increasing, when the graph achieves(theoretical) infinity, the secant line will be undefined, but that can't happen b/c if that occurs, y=x^2 wouldn't be func. anymore, therefore, y=x^2 never gets to infinity, it always reaches it. So seacant line keeps getting bigger till infinity but never gets undefined. Right?
Well, you basically agreed w/ me on the theory except the fact that the set doesn't contain itself, but if a set consist any number equal to its ordinal number(infinity), each infinity, and if a set consist of infinities of those, well, how is it bigger than those? Since one infinity can't be bigger than other? Sorry I know it is really confusing if you don't understand it, I'll just type it again b/c I am really tired right now.
Use whatever terminology you prefer, though I haven't heard that one. In general both forms are undefined (though values limiting toward those can act differently.)
No, that has nothing to do with x^2 being a function. Further, the secant does exist -- there's no reason that it can't be infinite valued if f is.
My problem with your terminology is that you're not explaining in what number system you're working, nor what your functions do. I've assumed so far you're using the extended reals (R plus two distinguished points +infty and -infty with the usual properties).
That makes no sense.
Yes, it's not undefined at any point. It becomes infinite-valued, in this example, when x is infinite.
Where do you get this idea? In fact a rather strong converse is true: any (possibly infinite) set is strictly smaller than its power set. That is, no bijection exists from any set to the set of that set's subsets.
Skhandelwal said:
I1. What does it mean when one reaches infinity faster than the other?(ex. y=x^3 graph compared to y=x^2.
To make this make sense, we will say f(x) diverges to infinity faster than g(x) (as x tends to something) if f(x)/g(x) tends to infinity too.
"reaching the speed of light" is not "infinity" in any sense of the word. One is a gerund the other a noun. It is the same as saying "is baking a cake" the same as "table"
Something is infinite if it is not finite. What is causing you to have issues with that?
There is no system of arithmetic I know of where you can even ask this question. It is not something that is permitted.
Now you want to talk about cardinals? By definition different cardinals are different. They are not anything to do with slope on tangent lines, though, or calculus.
infinity is not on the real plane, if you want to do this you need to learn projective geometry.
Not a bad summation. But it just means that the class of all cardinals cannot be a set.
These questions might seem random but they aren't
1. I read a big paper on this that 1/0 is undefined b/c even if 0 tries infinitely, it can never catch upto a real number except zero. Therefore, it is undefined, b/c we havn't really defined it. However, 0/0 is undeterminate b/c it can be any answer or any amount of answer. Depending on the answer... I have seen in calculus too that when it is 0/0, then that means that fraction was factorable and some expressions could cancel out, hence when a fraction has 0/0, it does have an answer, just unsure answer, unlike 1/0 which is like no sol. Therefore, 1/0 is undefined, and 0/0 is undeterminate. However, everywhere I go, even in school, everyone says undefined for both of them, I used to think that they are wrong and I don't want to brag about my intelligence over them on a single topic. But when one of you said that you never heard of it, I have started doubting myself, since I read that so long ago, I am not even sure where it is on the internet, except the fact that I read it from mathworld
2. I read in projective geometry,(has just gotten a book after talking to you guys) that parallel lines meet at infinity, that doesn't make sense to me.
No more "random" questions
3. What you said sort of doesn't make sense to me matt grime, not grametically or even mathematically, but logically, the answer to the last question. I mean why can't all infinities be in a set? Since they started using a symbol for each infinity, how is that a problem? I thought the paradox was that the set is bigger than all of those infinities since infinites are suppose to be equal to each other.(a fact I believed was true but proven to be wrong)
4. Why doesn't 1 infinity = another?(calc.)
5. I heard somewhere that infinity square is undeterminate, how do you figure that?
Btw, I didn't know such a cool subject as projective geometry existed, I don't want to miss out on more stuff I don't know, is there a place where I can get a list of all of kinds of science and math subjects and their descriptions? Like a two column list? Online would be fabulous.
Even if it tries infinitely? Poor guy, he just can't win.
There's a detail you're missing: the indeterminante form 0/0 isn't a string of symbols that represents the result of dividing one real number by another real number. It is a string of symbols that represents a form that an expression can take in the limit.
For computing limits, you have a theorem that if the limiting form makes arithmetic sense, then doing the arithmetic gives you the answer. Some other forms tell you the limit doesn't exist. Some others give you no information at all, and there are even more bizarre forms. But in all cases, the limiting form is not an arithmetic expression; it is a description of the form of the limit.
Although 1/0 and 0/0 make sense as limit forms, they make absolutely no sense as arithmetic expressions. In the arithmetic sense, they are both undefined.
The Euclidean plane sits inside the projective plane. The projective plane has "more" points though, which all lie in a single (projective) line. These points are called the "points at infinity", and that line is called the "line at infinity".
When they say "two parallel lines meet at infinity", what they really mean is that if you take two Euclidean lines, and extend them into projective lines, the resulting projective lines will intersect.
One of the axioms of projective geometry is "Every two distinct lines intersect in exactly one point".
Exercise: prove that the process of extending a Euclidean line to become a projective line consists of adding a single point to it.
