Is insulating and nonconducting the same thing?
  • Thread starter Thread starter pyroknife
Insulating and nonconducting refer to similar concepts in physics, where an insulating material does not allow electric current to flow. The discussion clarifies that the terms are often used interchangeably, as an insulator is inherently nonconductive. The context of electric fields and continuous charges is relevant to understanding these properties. Participants agree that if a sphere is described as insulating, it implies that it is nonconducting. Overall, the consensus is that insulating materials prevent electrical conduction.
pyroknife
We're currently during e field due to continuous charges. I've only seen problems like blah blah the sphere is nonconducting/conduct, but I saw a problem that says the sphere is insulating, does that just mean it's nonconducting?
As far as I know the opposite of conducting is insulating. So, yes.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
