kostarak
- 9
- 1
- TL;DR Summary
- I know that this subject is pretty saturated even thought i waited a few days.Its a generalized theoretical expiremental set up to try and measure one way speed of light,i just want any input on this but beware it will require a few minutes of your spare time.Thanks in advance.
Theoretical experiment for measuring one way speed of light
From 1905 to this day we have not experimentally measured the one way speed of light between a source to the detector only the roundtrip from the source to the detector and back again. We just assume that the speed of light is the average speed and it’s the same at all directions equal to c. But I think it is important to point out that this is just a convention not an empirically verified fact. The aim of this paper is to provide a general methodology using a theoretical experiment that aims, if it gets implemented, to prove or disprove that the speed of light is equal at least in two directions along the horizontal axis. It’s not meant to provide specific technical details and it will require some modifications if it ever gets attempted.
We can start setting up our theoretical experiment now, which I call “The Weight Race Experiment/Method”. First of all we need some kind of containment or room to experiment. For simplicity’s sake we will go with the room. So now we take an optical fiber of certain length and cut it exactly in half. We use a laser that can shoot a vertical light beam in two angled and connected mirrors that split the beam and redirect them into the two out of the four non connected ends of the fibers we just cut respectively. Now we attach a rigid rod above the optic fiber and also make the system able to rotate (except the laser and the mirrors) around its center of gravity which would be near the center of our fiber. Also our system will be supported by the wall in a way that the two spheres are facing downwards. We now attach at the two edges of the fiber two special identical in every way clamps that each hold two also identical in every way spheres(also when light hits the special clamps they move to the open position at exactly the same time). Keep in mind that we still try to make everything be level. Last step is to remove as much air we can from the room and get it as close to a vacuum as possible.
Once the whole system is at rest and the two weights are balancing each other out we start by shooting two simultaneous light beams at each edge of the fiber optic. If the speed of light is the same in all directions then the whole system will remain at the same position and not rotate. If it’s not then the center of gravity will shift for a very small amount of time and it will make the (fiber/device/rod) system rotate and depending on how different the speed of light is in each direction the angle will increase in value relative to the original rest position of the whole system. That means that the difference between the different speeds of light and the angle created are analogous. Larger difference results in larger angle, which we can measure using an already built in sensor before the experiment even start.
