I Is it feasible to measure one way speed of light this way?
kostarak
TL;DR Summary
I know that this subject is pretty saturated even thought i waited a few days.Its a generalized theoretical expiremental set up to try and measure one way speed of light,i just want any input on this but beware it will require a few minutes of your spare time.Thanks in advance.
Theoretical experiment for measuring one way speed of light
From 1905 to this day we have not experimentally measured the one way speed of light between a source to the detector only the roundtrip from the source to the detector and back again. We just assume that the speed of light is the average speed and it’s the same at all directions equal to c. But I think it is important to point out that this is just a convention not an empirically verified fact. The aim of this paper is to provide a general methodology using a theoretical experiment that aims, if it gets implemented, to prove or disprove that the speed of light is equal at least in two directions along the horizontal axis. It’s not meant to provide specific technical details and it will require some modifications if it ever gets attempted.
We can start setting up our theoretical experiment now, which I call “The Weight Race Experiment/Method”. First of all we need some kind of containment or room to experiment. For simplicity’s sake we will go with the room. So now we take an optical fiber of certain length and cut it exactly in half. We use a laser that can shoot a vertical light beam in two angled and connected mirrors that split the beam and redirect them into the two out of the four non connected ends of the fibers we just cut respectively. Now we attach a rigid rod above the optic fiber and also make the system able to rotate (except the laser and the mirrors) around its center of gravity which would be near the center of our fiber. Also our system will be supported by the wall in a way that the two spheres are facing downwards. We now attach at the two edges of the fiber two special identical in every way clamps that each hold two also identical in every way spheres(also when light hits the special clamps they move to the open position at exactly the same time). Keep in mind that we still try to make everything be level. Last step is to remove as much air we can from the room and get it as close to a vacuum as possible.
Once the whole system is at rest and the two weights are balancing each other out we start by shooting two simultaneous light beams at each edge of the fiber optic. If the speed of light is the same in all directions then the whole system will remain at the same position and not rotate. If it’s not then the center of gravity will shift for a very small amount of time and it will make the (fiber/device/rod) system rotate and depending on how different the speed of light is in each direction the angle will increase in value relative to the original rest position of the whole system. That means that the difference between the different speeds of light and the angle created are analogous. Larger difference results in larger angle, which we can measure using an already built in sensor before the experiment even start.
kostarak said:
Summary:: I know that this subject is pretty saturated even thought i waited a few days.Its a generalized theoretical expiremental set up to try and measure one way speed of light,i just want any input on this but beware it will require a few minutes of your spare time.Thanks in advance.
We can start setting up our theoretical experiment now, which I call “The Weight Race Experiment/Method”. First of all we need some kind of containment or room to experiment. For simplicity’s sake we will go with the room. So now we take an optical fiber of certain length and cut it exactly in half. We take a special device that can shoot two light beams from two opposing holes located at each side of the machine simultaneously and we attach the two out of the four non connected ends of the fibers we just cut in the two holes accordingly. Now we hang our system of [fiber-device-fiber] from the ceiling of the room and try to make it as level as possible. We now attach at the two edges of the cable two special identical in every way clamps that each hold two also identical in every way spheres(also when light hits the special clamps they move to the open position at exactly the same time). We also add two more identical clamps/spheres in the center points between the exposed ends of the fiber and the ends in which our special device is placed [clamp-fiber-clamp-fiber-device-fiber-clamp-fiber-clamp]. Keep in mind that we still try to make everything be level so we might also have to use strings to support the optic fiber to prevent from bending. Last step is to remove as much air we can from the room and get it as close to a vacuum as possible.
Now we can start our experiment. At a predetermined time the device shoots simultaneously two light rays to the left and to the right edge of the fiber respectively. If the speed of light is constant to all directions then the light beams will reach the first clamps in each direction at the same time thus releasing the first two spheres at exactly the same moment while the next two at an expected defined delay. If that’s not true and the speed of light is different at different directions then we would notice a difference in the value of that delay at both pairs, from which we could calculate the speed of light in each direction. If we can get the pair of spheres close enough we can use something simple like a camera to record them free falling.
There is another variation of this experiment that provides similar results but it does not require collecting any info in real time.
The variation of this experiment first of all is missing the first set of clamps so the only clamps it has are located at the exposed ends of the fiber respectively. Now we attach a rigid rod above the optic fiber and also make the system able to rotate around its center of gravity which would be near the center of our special device. Also our system will be supported by the wall and not from the ceiling in a way that the two spheres are facing downwards. Once the whole system is at rest and the two weights are balancing each other out we just repeat the same process as before by shooting two simultaneous light beams at each edge of the fiber optic. If the speed of light is the same in all directions then the whole system will remain at the same position and not rotate. If it’s not then the center of gravity will shift for a very small amount of time and it will make the (fiber/device/rod) system rotate and depending on how different the speed of light is in each direction the angle will increase in value relative to the original rest position of the whole system. That means that the difference between the different speeds of light and the angle created are analogous. Larger difference results in larger angle, which we can measure using an already built in sensor before the experiment even start.
First you should estimate what kind of difference in the speed of light you think you might observe. Then ask how that difference would be detected in the systems you are proposing and see if those detection schemes make sense. For example, if the difference amount to 1ns or one billionth of a second, could your system detect a 1ns difference in the falling weights or would such a small difference be swamped by experimental error?
That depends a lot at specific technical details of the expirement,how exactly is set up,whats the accurancy of our measuring devices etc etc.Do not get stuck too much in technical details,try to think how feasible the general methodology is.
Draw a schematic of your proposed setup please. But in general the feasibility depends of the details of the measurements. Thanks.
How do you expect to see the falling weights? Using light I suppose, which needs to propagate back to where you started. So how is it a one-way measurement?
Likes nasu
You will see them vertically to the optic fiber,so its a two way trip from you to the weights and back.I will try to draw it really quick
Before jumping in, is there any argument whatsoever that would convince you that you are wrong?
Likes Astronuc, nasu, jbriggs444 and 1 other person
Yes that's what i am looking for.If you have it i am actually glad to hear it.
And what do you think happens to the recording on a camera if the one-way speed of light is anisotropic?
There is simply no possible experiment that can measure the one way speed of light independently of your synchronization convention
Dale can you please explain more the problem with the camera please? I am imagining using the camera from the side view like i posted above.
Really? If you think that you understand this stuff so well that you can propose an experiment which eluded the most brilliant minds of the last century then shouldn’t you be able to do this analysis in exact mathematical detail yourself?
I am sorry, but ever since that silly Veritasium video we have had a deluge of people doing exactly what you are doing. I was patient for the first several and had hoped that the phase had past. But frankly I am annoyed by it.
It is impossible! It is not a matter of clever experimental design, it is a matter of definition.
Likes nasu
(emphasis mine)
There's your problem. How do you ensure these events at different places are simultaneous.
The Aspect experiment was designed to look at violations of Bell's inequalities but it relied on the isotropy of the speed of light. Two detectors were placed at equal distances from a source that generated two correlated photons moving in opposite directions. A coincidence circuit ensured that only simultaneous counts by the detectors were accepted. Simultaneous events were detected and accepted. What do you think this means?
First of all i do not think this a magic or clever expiremental set up that will measure the one way speed of light,as you said the most brilliant minds of the last century tackled this problem and failed.I do not try to prove anything its just an idea (that yes originated by the Veritasium video) in which i wish input exactly because of my almost certainty that there is a problem which i am unable to find.
Also,if you are annoyed or frustrated by this no one forces you to read it or reply to it.Where else is better to get feedback than from a forum.
Likes PeroK
Thats the problem that starts to be uncovered and by other frums vanad. Its not about leaving the holes at the same time more of starting at the same time from a single point. I am not knowledgeable enough to know such a device so i assumed that there has to be way to produce two opossing light beams at the same time with some process.
That assumption that slipped by is probably the problem.
Watch this video by Veritasium. I think your idea is one of the rejected methods discussed in the video. Pay close attention to the concept of simultaneity; that's where most people go wrong.
Likes PeroK
You certainly did not express that in your OP, which reads very much as though you believe that your “general methodology” will work.
Then I am glad I helped you find it.
A camera records light coming from different directions. If the one way speed of light is anisotropic then the image will be distorted due to the anisotropic delays compared to isotropic delays.
Thanks dale now i see the problem,also i should explain more my intentions because of all this Veritasium surge.
Since its useless i edited out the first part and left the second in which i still have not gotten feedback.I slightly modified the special device i was using in hopes of not triggering any simultaneity problems (i will) but i am more interested if such a measumerent could be done using shifting of the center of mass.
It is not possible to not trigger simultaneity. The one way speed of light is DEFINED as the time it takes for light to travel a fixed distance according to a pair of synchronized clocks. There is no way around the issue because it is part of the definition of the thing you are trying to measure.
In the second setup if the speed of light is anisotropic then so will the speed of sound be.
Ok then if that's the problem then indeed there is no way arround.I will delete any comments that are not needed.
The main argument is that this is not really an experiment problem, as such, but the definitions in modern physics do not allow a one-way speed to be unambiguously defined (and, if it cannot be defined, it cannot be measured). Physics is not perhaps as clear cut as mathematics, but you may as well try to prove that ##1## is not a prime number.
It really doesn't matter how clever your experiment is, the impossibility of a one-way measurement is embedded in the modern notions and definitions of time, space and speed.
Likes phinds
Maybe it would help to talk about "speed in general", not "speed of light" here. This would avoid the misconception, that there is something special about light in this context.
Likes Dale and Ibix
Please don't do that. Changing the question after it has received answers is not conducive to communication.
That's the polite way to put it. If you were from Glasgow you could say:
"Gonna no dae that".
https://www.eathaggis.com/product/gonne-no-dae-that-mug
I was going to suggest you could put that mug on your Christmas present list, but they're sold out!
Your experiment might work as an idealistic thought experiment to detect a difference in the speed of light in different directions. (EDIT: But it won't work even for that.) I assume that you realize that there are so many difficulties that it is not a practical experiment. In addition to that, relativity theory has a lot of complications, such as the apparent rotation of a moving object. With all the complications, what could you really conclude (with enough evidence to convince skeptics) when the result inevitably shows no difference in speed? The beauty of the experiments that used light going in a "round-trip" is that they remove so many of the practical complications. They were so convincing that even the most skeptical people had to take the bizarre results (that the speed of light and the speed of the platform do not add) seriously.
Not everyone knows what you are referring to and why you are upset. What video was that? What exactly is impossible? Thanks.
No it won't. Any "one way speed measurement" either depends on clock synchronisation (which involves an assumption of the one way speed of light) or is a disguised two-way measurement. This one depends on the speed of light in one direction and the speed of sound in the other, so is of the "disguised two-way measurement" variety.
Likes cianfa72, Vanadium 50 and PeroK
I agree, but I think that the experiment described is really to detect any difference in speed, not to measure the speed. Even for that use, I don't think that the experiment described is worth figuring out the details. That is why I said "might work" because I don't want to quibble about all the reasons that it would not work.
How is that different from measuring the one-way speeds? If I know the two way speed then I know the average one-way speed. Knowing that and the difference gets me the one way speeds - which are conventional, hence implying that the difference is conventional too.
  • #31
How is the speed of sound involved?
  • #32
That's how the release of the weights is communicated through the apparatus. It can't be perfectly rigid because that would imply an infinite speed of sound in the apparatus. So the apparatus flexes rather than tipping, at least until the mechanical waves from the two releases meet.
Likes Dale
  • #33
I would prefer that the OP realize how clever the Michelson-Morley experiment was than worry about the details of his deceptively complicated experiment. I would rather delete my post than divert this thread.
  • #34
How does clock synchronisation assume the one way speed of light when two atomic clocks can be synchronised while together and then moved a distance apart for the experiment?
  • #35
Look up "slow clock transport". In short, time dilation is only negligible (for measurements of the speed of light) in the limit of small transport velocity when the speed of light is assumed to be isotropic.
Likes bob012345
  • #36
Measuring the one-way speed of light is impossible without adopting a simultaneity convention.
  • #37
Is the synchronicity requirement implicitly doing that? Thanks.
  • #38
You mean the clock synchronisation? Yes, choosing your methodology for that is the operational aspect of choosing a simultaneity criterion.
Likes bob012345
  • #39
The speed of light is the same in both directions - and this is not simply assumed.
The Michelson-Morley Experiment was first performed in 1887 - and has certainly been repeated many times since 1905. The experiment compares the speed of light in two perpendicular directions. The entire interferometer can be rotated while the comparison is made, so if light traveled at a different velocity in one direction than another, the interference pattern would change as the apparatus was rotated.
When the experiment is conducted in an inertial frame, no such shifting interference pattern is observed.
  • #40
No, the Michelson-Morley experiment confirms that the two-way speed of light is isotropic. It doesn't (and cannot) say anything about the one-way speed of light, which was the question in this thread.
  • #41
While the OP is to be commended for the complexity of his device, people who say they have found a way to measure the one-way speed of light should be treated the same as people who claim they can solve one equation in two unknowns.
Specifically, the one-way speed of anything (not just light) going from A to B is:
v = \frac{x_B-x_A}{(t_B - \delta t)-t_A}
where δt is the difference in clock syncronization from A to B. In Newtonian physics, δt = 0. In Relativity, you tell me what one-way speed you want, and I'll tell you the clock syncronization convention to use. It's one equation in two - count 'em, two - unknowns.
Likes Astronuc and etotheipi
  • #42
Let me work this through...
Let's call the 2-way (or all way) length of one arm L1 and the corresponding length of the other (perpendicular) arm L2. Then we have the speed of light in the North, South, East, and West direction will be cN, cS, cE, and cW respectively.
And we will apply this additional constraint: L1 and L2 will not be precisely equal. They will be off by at least a few wavelengths - enough to be noticeable as the experiment is conducted.
If the measurement is first made with L1 oriented North/South, the interference pattern will reflect the difference L1(1/cN+1/cS)−L2(1/cE+1/cW). Then as the device is rotated clockwise, the interference pattern reflects a range of other cX vs. c(X+π/2) 2-way combinations, and since the interference pattern is not shifting, all of these also yield the same value.
That is: T=L1(1/cX+1/(cX+π))−L2(1/(cX+π/2)+1/(cX−π/2)) is a constant.
So after 90 degrees, you will have:
T=L1(1/cN+1/cS)−L2(1/cE+1/cW)=L2(1/cN+1/cS)−L1(1/cE+1/cW).
0=(L1−L2)((1/cN+1/cS)−(1/cE+1/cW))
(1/cN+1/cS)=(1/cE+1/cW)
More generally:
(1/cX+1/(cX+π))=(1/(cX+π/2)+1/(cX−π/2))
At this point, we cannot even claim that the 2-way path is isotropic - there could be some pattern (like a square) that repeats every 90 degrees. But if we repeat the experiment with (for example) the arms at 1.5 radians to each other instead of 90 degrees, we demonstrate that the two-way is isotropic.
This only says that the sum of the two time periods remains a constant as the direction changes.
So it seems you (@Ibix ) are right.
Letting C=T/(L1−L2)=1/cX+1/(cX+π) (a constant).
The the average time for each opposing direction would then always be proportional to C/2.
We can define a periodic function f(X) that indicates how much the transit time changes from the average:
f(X)=1/cX−(C/2)
So C=1/cX+1/(cX+π)=(C/2+f(X))+(C/2+f(X+π/2))
Thus f(x)=−f(X+π/2).
So if we add one more constraint, that f(X) is a continuous function, we can demonstrate that there is at least one direction X0 such that f(X0)=−f(X0+π/2)=0. For direction X0, the speed of light is the same in both directions.
If there really is no way to determine f(X) for an inertial reference frame, then by Occam's Razor, we should take f(X)=0.
  • #43
To be precise here, by Occam's razor we should assume that ##f(x)=0##... and that is exactly the point.
We are assuming that the one-way speed, which we cannot measure, is equal to the two-way speed, which we can measure. Occam's razor says that's a good assumption, when we consider the consequences we find that it is a very helpful assumption, so helpful that it would be perverse to reject it, no one will seriously tell you that this assumption is invalid and that you shouldn't trust results based on it (as long as you don't erroneously misinterpret a coordinate velocity, which is a different problem)... but it is still an assumption, not an observational fact confirmed by an experiment.
Likes Ibix and PeterDonis
  • #44
How do you propose to ensure that your measurements are the same in all directions, given the definition of the metre is based on a fixed value for the speed of light?
  • The metre, symbol m, is the SI unit of length. It is defined by taking the fixed numerical value of the speed of light in vacuum c to be 299 792 458 when expressed in the unit m s–1, where the second is defined in terms of the caesium frequency
    Cs.
  • #45
Sorry for dragging this on. But what is bugging me is no one has mentioned entanglement. Is it possible to synchronize a clock at the destination using an entangled photon at the moment a test photon is released at the source to measure the oneway speed of that test photon?
  • #46
No.
  • #47
No. This idea doesn’t work for the same reasons that you can’t use entanglement to send any message. Google for “no communication theorem”, or check out some of the many threads over in the QM section.
  • #48
Didn't Dr Michelson settle this argument with the ether drift experiment? He did the first one in my home town of Cleveland, but you can buy the stuff to do it in your own physics class. I wonder if all this interest in the 'one-way' speed of light is perhaps an effort to rehabilitate the luminiferous ether still so beloved by pseudoscience.
  • #49
No - this is a different topic. See post #40 and responses to that.
  • #50
Didn't someone calculate a reasonable value for c by astronomical observation?
Procedure (I think.) :
Note the time T1 o'clock when a star peeks out from behind some heavenly body (a planet, maybe) on a night when that h.b. is at distance D1 from the earth. On another night, six months later, note the time T2 o'clock when we see the same star emerge from behind the same h.b., but now that h.b. lies at a distance D2 from the earth. c = (D1-D2)/(T1-T2). The light always goes the same direction, and I think that the speed of light came out to be about 3e8 m/s.
