bill nye scienceguy!
- 121
- 0
to spontaneously develop an instability, i.e. without some external force acting on it?
The discussion centers around the concept of stability in systems, specifically whether a stable system can spontaneously develop an instability without external forces acting on it. Participants explore definitions of stability and provide examples to illustrate their points, including a hypothetical scenario involving a person inside a box.
Participants do not reach a consensus on whether a stable system can spontaneously develop instability. Multiple competing views remain regarding the definitions of stability and the role of external forces.
Participants express differing interpretations of stability, including conditional stability and the effects of internal versus external forces. The discussion highlights the complexity of defining stability in various contexts.
Do you mean like if you lock me up in a box sitting on the floor, is it possible for me, inside the box, to tip the box over?bill nye scienceguy! said:to spontaneously develop an instability, i.e. without some external force acting on it?
I'm pretty sure the point of the OP's question is to ask if this can happen without introducing energy from an external source.DaleSpam said:In general it is always possible to add enough energy to a system to destabilize it. Stability refers to a system that returns to its original state after a small input of energy.
A box on the floor is stable, if you tip it a bit it will rock back in place. It is possible to add enough energy to tip the box completely over or even break the box.
What about the example in post#3 of me inside the box?russ_watters said:I agree that it sounds to be, by definition, impossible.
Who said anything about creating energy? Is there anything that says the closed system cannot contain stored energy, like say, a bored Web Developer with a point to make?AFG34 said:you can't create energy, so no it can't be
If it is possible to tip the box over, then it isn't stable.DaveC426913 said:What about the example in post#3 of me inside the box?
Not at all. If I turn myself in a circle inside the box, it will rotate in the opposite direction. True, its CoM will not have moved, but its orientation has.Crosson said:If you manage to tip the box over, its only because of the force of the floor, which is an external force.
To imagine a closed system, imagine trying to tip the box over in intergalactic space (impossible).
You sure about that definition?russ_watters said:If it is possible to tip the box over, then it isn't stable.
The way the question in the OP is worded, it is basically the same as asking if it is possible for 1 to equal 2. We don't need to nitpick the definition when the OP used two words with opposite meanings and asked if they can be equal.DaveC426913 said:You sure about that definition?
DaleSpam said:I would say that a person in a box is a conditionally stable system. The condition being that the person keeps themselves within certain bounds (below a certain height and velocity etc.) within the box. If the person exceeds those bounds then the box can spontaneously tip over, but if the person does not exceed those bounds then small external inputs will not result in the box tipping over.
