Is it possible to amplify uniforn current?
  • Thread starter Thread starter aekanshchumber
    Current
Uniform currents can be amplified, but high gains may introduce offset issues, causing non-zero signals even with zero input. Operational amplifiers, particularly instrumentation amplifiers, are recommended for this purpose. A current-voltage conversion circuit using a photodiode connected to an op-amp can effectively amplify the induced current. The gain is determined by a resistor connected to the op-amp output. If difficulties arise with a DC approach, AC coupling might be necessary despite initial preferences.
aekanshchumber
Hello,
Will please anyone help me out of this, i want to know that can a uniform current no matter a.c or d.c be amplified. I am working on a experiment in which the current which will e induced by a photodiode will have to be amplified. I know that we can amplify A.C using transformers also amplification is also done in a t.v set.
But the probem is we know that signals in both the transformer and t.v set are not uniform but in this experiment we do not know that will current indused will be uniform or non-uniform as it all depend on the frequency of the light and its intensity at the moment.
any kind of help is really appreciated.
Thanx.
aekanshchumber said:
Hello,
Thanx.
You can amplify uniform currents, but in general you will have problems with extremely high gains in doing this, due to offset problems. This means that zero current in will tend to produce some signal that is not zero, due to imperfections in the amplifier, if the gain is high enough. Furthermore, the signal so produced will tend to "drift" with time.
I think the best circuits for this are still operational amplifiers - the high priced high performance version of these are called instrumentation amplifiers
I think a standard current-voltage conversion would be your best bet offhand, connect one end of the photodiode to a bias voltage, the other side of the photodiode to the negative terminal of an op amp/ instrumentation amplifier, and connect a resistor from the output of the op amp to the negative terminal. The positive terminal of the op amp goes to a reference signal / ground. (Usually you need positive and negative supplies for an op amp circuit).
The gain of the circuit will be set by the value of the resistor, i.e. the output current will be the photodiode current times the value of the resistor.
http://ezphysics.nchu.edu.tw/prophys/ael/File/Datasheet/AD648JQ.pdf
has, if you look far enough, a "dual photodiode" amplifier, you just want 1/2 of that circuit.
I really don't know much about the specific op-amp discussed in the data sheet, there may be better ones for your purpose, though it is promising that your application is discussed. The input current and offset voltage look quite low - OTOH it may be pricey, usually good specs come at a high price.
I don't quite understand what you're trying to accomplish. If you run into too many problems with the DC coupled approach, you may have to resort to AC coupling, even if you don't want to.
You might consider moving this thread to the electrical engineering section of the board as well...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
