Is it possible to change the chirality of an atom like this?
The discussion centers on modifying the chirality of an amino group attached to a chiral carbon. The original poster is exploring various methods, including nucleophilic addition to the carbonyl group, SN2 reactions for stereochemistry inversion, and temporarily altering the amino group to achieve a racemic mixture. They also consider converting the amino group to a double bond to make it achiral and then restoring its chirality. Another idea involves deprotecting the carboxyl group and using Kolbe electrolysis with controlled amounts of mono-esterified oxalic acid to favor dimerization. Responses highlight the complexity of modifying chirality without synthesizing new compounds and suggest that more information about the entire molecule is necessary for tailored advice.
mycotheology
Heres the chiral center:
I want to change the chirality of the amino group. I was wondering if I can do it through some kind of nucleuphilic addition to the carbonyl group, while adding something to adding a metal that will coordinate the amino group and drag it back or force it to change chirality or something like that.
Another idea I had was to use some kind of SN2 to invert the stereochemistry, but I have no idea how to do that. Is there any way I can remove a hydrogen from that chiral center in order to temporarily turn it trigonal planar, then when I re-hydrogenate it, at least I'd have a racemate.
Or would it be possible to tenporarily make the amino group achiral by converting it to a double bond or something? Then when its trigonal planar, I suppose I could figure out how to get the right stereochemistry.
Or here's another idea, maybe I could deprotect the carboxyl group, then run a kolbe electrolysis on it, but I will put an excess of mono esterified oxalic acid so that the majority of the my product will dimerise with the oxalic acid, rather than itself. Only problem there, is the oxalic acid will dimerise with itself, but I suppose I could add tiny amounts of the oxalic acid in at a time. This seems like it just might work.
Any ideas?
Chemistry news on Phys.org
You mean chirality of the carbon to which the amino group is attached?
If it is for an amino acid there are probably hundreds of papers out there that describe chiral synthesis.
Yeah I meant chirality of the carbon. No, its not for an amino acid and synthesising it isn't an option in this case, I need to find a way to modify it.
There may be ways but it is hard to give advice without seeing the whole molecule and knowing what you are really trying to do.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
