Is it possible to sumate this series?
  • Thread starter Thread starter Petar Mali
    Series
Petar Mali
\sum^{\infty}_{n=0}(2n+1)e^{-Cn(n+1)}
C - constant
If C is negative or 0, then no, obviously. If C>0, then yes...
Yes C>0. But I don't ask you if it convergate but can you summate analyticaly? Or you must use some numerical methods?
This is called finding a "closed form" for the series. I don't think one exists. So numerical approximation is the best one can do.
A theta function or relative ... because of the quadratic in the exponent.
That looks like the sum you need to do if you were to calculate the Partition function for a quantum mechanical dumbell. That sum cannot be computed in closed form. The typical approximations are to assume either low temperature ( C \rightarrow \infty), in which case the sum is approximately
1 + 3e^{-2C} + \ldots .
The other limit is high temperature, C \rightarrow 0, in which case the sum is approximately an integral,
\int_0^\infty dn~(2n+1)e^{-Cn(n+1)},[/itex]<br /> <br /> which is easily solved by substitution.<br /> <br /> Systematic corrections to the integral form can be computed using the Euler-Maclaurin formula:<br /> <br /> <a href="http://en.wikipedia.org/wiki/Euler-Maclaurin_formula" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://en.wikipedia.org/wiki/Euler-Maclaurin_formula</a>
<br /> <br /> Yes that is my problem. Sum is<br /> <br /> Q_1=\sum^{\infty}_{l=0}(2l+1)e^{-\frac{\theta_r}{\theta}l(l+1)<br /> <br /> where<br /> <br /> \theta_r=\frac{\hbar^2}{2I}<br /> <br /> Why we can say that if \theta&amp;gt;&amp;gt;\theta_r<br /> <br /> Q_1=\int^{\infty}_0dl(2l+1)e^{-\frac{\theta_r}{\theta}l(l+1)?
