Is M(x,y)dx + M(y,x)dy Always Exact?
  • Thread starter Thread starter Saladsamurai
Saladsamurai
I thought that this was an interesting question.
(a) Show that (x^3 + y)dx + (y^3 +x)dy = 0\qquad(1) is exact.
(b)More generally, is M(x,y)dx + M(y,x)dy\qquad(2) exact? Explain.
Test for exactness: \left(\frac{\partial{M}}{\partial{y}}\right)_x=\left(\frac{\partial{N}}{\partial{x}}\right)_y[/itex]<h2>The Attempt at a Solution</h2><br /> (a) Applying the test is simple enough. 1 = 1. Exact.<br /> <br /> (b) Now this is how I am thinking about (b). Please correct me if I am wrong. M is simply a rule. It is in the form M(x<sub>1</sub>,x<sub>2</sub>). It tells us how to operate on whatever is in the x<sub>1</sub> and x<sub>2</sub> spot. In equation (2), in the first term, x<sub>1</sub> = x and x<sub>2</sub> = y , and in the second term x<sub>1</sub> = y and x<sub>2</sub> = x. Wouldn&#039;t this imply that the equation will always be exact? Is there a way to show that it is or isn&#039;t?<br /> <br /> Any thoughts?
Suppose there is a function z=f(x,y). Your M and N are partial derivatives of z w.r.t x and y
M = \left(\frac{\partial{z}}{\partial{x}}\right), N = \left(\frac{\partial{z}}{\partial{y}}\right)
By taking a derivative of M with respect to y, and taking derivative of N with respect to x, you are essentially testing for exactness. It is an exact differential equation if and only if:
\left(\frac{\partial{}}{\partial{y}}\right) \left(\frac{\partial{z}}{\partial{x}}\right) = \left(\frac{\partial{}}{\partial{x}}\right) \left(\frac{\partial{z}}{\partial{y}}\right)
Your objective is to find z.
I think to make it clear you need an example:
Suppose there are 2 functions, z1= 2*x^2 + y^2, z2 = x^2 + 2*y^2
M(z1) = 4x, N(z1) =2y M(z2) = 2x, N(z2) = 4y
My = 0, Nx = 0 My(z2) = 0, Nx(z2) = 0
So if I give you (4x)dx + (2y)dy = 0, your solution will be integral(M(z1))dx + integral(N(z1))dy =2x^2 + y^2 , and
if I give you (2x)dx + (4y)dy = 0, your solution will be integral(M(z2))dx + integral(N(z2))dy = x^2 + 2y^2.
This was only possible because both M and N were describing the same function z
Hi cronxeh :smile: I understand the test for exactness and how to find F(x,y) if it is exact. The question in part (b), is if equations of the form (2) are always exact. I am not sure how to apply what you have posted to part (b).
So wait you saying part b is not a typo? You actually want to find whether M(x,y)dx + M(y,x)dy = c is always exact?
You can try to see what happens by developing M(x,y) into Taylor series around (0,0) and try on M(x,y)=x^my^n. Once you are done, use (x_0,y_0) instead of (0,0). This may give you some insight and intuition to start with.
Indeed it is not a typo.
Notice that when you write
\frac{\partial M(x,y)}{\partial x} it can be written as well as
\left(\frac{\partial M(s,t)}{\partial s}\right)_{s=x,t=y}
or
\left(\frac{\partial M(t,s)}{\partial t}\right)_{t=x,s=y}
It's all the same. Now, you can do it.
Hint (Big hint): Find a counterexample. It's not hard.
