Is matrix hermitian and its eigenvectors orthogonal?
7 replies · 2K views · last reply
bugatti79
I calculate
1) ##\Omega=
\begin{bmatrix}
1 & 3 &1 \\
0 & 2 &0 \\
0& 1 & 4
\end{bmatrix}## as not Hermtian since ##\Omega\ne\Omega^{\dagger}## where##\Omega^{\dagger}=(\Omega^T)^*##
2) ##\Omega\Omega^{T}\ne I## implies eigenvectors are not orthogonal.
Is this correct?
The matrix ##M = \begin{bmatrix} 1 & 0 & 0 \\ 0 & 2 & 0 \\ 0 & 0 & 3 \end{bmatrix}## does not satisfy ##M M^\dagger = I##, but its eigenvectors are orthogonal.
Ok then my 2)assumption is not correct thus I proceeded to calculate the eigenvectors for the following eigenvalues ##\lambda=1,2,4## and then check for orthogonality
##\lambda=1##
##\begin{bmatrix}1& 3 & 1\\ 0& 2&0 \\ 0& 1 &4 \end{bmatrix}\begin{bmatrix}x_1\\ x_2\\ x_3\end{bmatrix}=\lambda \begin{bmatrix}x_1\\ x_2\\ x_3\end{bmatrix}##
In component form I get
##(1-1)x_1+3x_2+x_3=0##
##0+(2-1)x_2+0=0##
##0+x_2+(4-1)x_3=0##
I am confused here for 2 reasons
1) How to deal with ##(1-1)x_1##
2) the 2nd line suggest ##x_2=0## but on the 3rd line ##x_2=-3x_3##
Not sure how to proceed from here...
Any help will be appreciated.
I'm not sure why ##x_1##, ##x_2##, and ##x_3## are coming into the process. To compute eigenvalues you solve for ##\lambda## by expanding ##det(M - \lambda I) = 0## then finding roots. You seem to be skipping ahead to the part where you know a specific lambda and want to find the associated vector.
The khan academy video on eigenvectors might help.
Thanks for the video, very useful
I have expanded ##det(\Omega - \lambda I) = 0## to get
##\begin{bmatrix}1-\lambda& 3 & 1\\ 0& 2-\lambda&0 \\ 0& 1 &4-\lambda \end{bmatrix}##
For ##\lambda=4## say we get the following
##\begin{bmatrix}1-4& 3 & 1\\ 0& 2-4&0 \\ 0& 1 &4-4 \end{bmatrix}\begin{bmatrix}v_1\\ v_2\\ v_3\end{bmatrix}=0##
##-3v_1+3v_2+v_3=0##
##-2v_2=0##
##v_2=0##
If we let ##v_1=1## then ##v_3=3##. Our eigenvector for ##\lambda=4## is (1,0,3)
For ##\lambda=1## I have difficulty because
##\begin{bmatrix}1-1& 3 & 1\\ 0& 2-1&0 \\ 0& 1 &4-1 \end{bmatrix}\begin{bmatrix}v_1\\ v_2\\ v_3\end{bmatrix}=0##
##3v_2+v_3=0##
##v_2=0##
##v_2+3v_3=0## but I cannot determine what ##v_1## is...?
You can check that for ##\lambda = 1## every vector with ##v_2=v_3=0## and ##v_1\in \mathbb{C}## is an eigenvector.
Do that.
I would advise brushing up on solving systems of linear equations. Because that's where your main issue seems to be located.
If you have a solution, always check that the vectors you found actually give the correct eigenvalues.
##-2v_2=0##
##v_2=0##
##3v_2+v_3=0##
##v_2=0##
##v_1## can be anything. You can choose it to be 1, for example. Remember that any multiple of an eigenvector is also an eigenvector with the same eigenvalue.
OK guys, thank you.
I can see how that holds for ##\lambda=1##.
Onto my next problem :-)
