Is MIT Prof. Lewin wrong about Kirchhoff's law?
  • Context: Undergrad
  • Thread starter Thread starter sarumonkee
    Law Mit
347 replies · 87K views
sarumonkee said:
I don't get your comment. You say if the model is changed to include an element that affects the circuit, you get the right answer. If the model ignores the "lumped element" that is the voltage source (or inductor), then it is not wrong? How can you justify ignoring the effect of the very thing that is coupling energy into the system? I just don't get it. Maybe it is a difference in thought between physicists and engineers...
Just because something is "spread out" around a circuit doesn't mean we can ignore it and remove it from the model. It seems like that is akin to saying a resistor can be ignored because it is a collection of atoms, and therefore the resistance is distributed.
Well, let's say you are measuring the circuit, unaware that induction is taking place. You measure the voltage along different paths, & the sum around the loop is non-zero. This should tell you that induction is going on. Of course, the mag field is what couples energy into the loop. But if you don't see it, & are unaware of its presence, you will make measurements at odds with KVL. That is the point.
Dr. Lewin was merely illustrating that the sum of voltages around a loop may be non-zero. If non-zero, however, the value is exactly equal to the induced emf. Thus if said emf is added to the circuit model in the form of an independent source/generator, whose voltage value equals that of the induced emf, then it will balance & KVL will hold, as the sum around the loop is now zero.
What I take from all this is that fields are distributed parameters, & circuits are lumped. When jumping between the two, we must be careful. In circuits, the sum around a loop is zero per KVL. If the circuit itself is acting as an inductance with an incident time varying mag field upon it, then the sum around the loop is the induced emf, not zero. Lumping the induced emf into a discrete source balances the loop restoring zero net voltage, & KVL is valid.
Pretty easy, if you ask me.
Claude
@yungman: The source is connected to the other coil, which propels the magnetic field, so how can it be drawn in a circuit which doesn't contain it? The professor was drawing a schematic diagram of the real set-up, not any model.
Besides, please look at the bold part of my previous post. There is induced emf on the wire, and by your estimation, it constitutes 90% of the total induced emf. However, this is not the only emf inside the circuit. Due to this extra emf, the 90% is simply "shifted" from the wire to the resistors. The equation for a loop remains the same, but the real thing happening inside the circuit is all that is on the resistors. The extra emf is NOT LESS THAN 10%.
Thanks for joining the debate and all the best to your work :wink:
@sarumonkee: I would like to see your experiment with my own eyes and learn, too :smile:
stevenb said:
Why do you think that emf on the wire is a surprise to us? Faraday's law tells us that there is a 1V emf around the loop. This new setup of sarumonkee has tiny leads on the resistor that are soldered right next to each other, and then a long length of wire to finish the loop. Wouldn't we expect emf in the wire?
Faraday's law tells us something else about this new measurement setup. There is also emf on the scope wires. Why? Because the scope leads are a valid completion of the loop with equal validity as the main circuit wire. For this reason, if you take a loop through your scope and probes and complete it through the wire, the net emf is zero because the wire and the scope leads have equal emf in opposite directions around this new loop. This makes sense in terms of Faraday's Law because there is no net flux change inside this new loop.
What is mysterious to me is that sarumonkee got a reading of emf on the scope when the loop emf being measured should be zero. Yes, there can be emf on the wire, but not in the measurement loop. This is the underlying reason that Lewin's analysis is correct. When you analyze a system with Faraday's law using loops, these details take care of themselves, and you don't need to identify the location of the emf. So, I'm highly suspect of the measurements of sarumonkee, but it's quite possible I'm misinterpreting the method he used. Unless I see the layout and know the method, I can't really judge. I am waiting for him to do more verifications and checking and then to post the details so we can be convinced of his methods. He should follow Lewin's lead and verify all loops obey Faraday's Law. This is a good check to help give confidence that the measurement techniques are valid. I commend sarumonkey for doing real measurements and getting to the bottom of this personally, and it's only fair to give him adequate time and not rush him.
OK, my bad, I can't resist to take a peek here even though I should take more peek at my books.
Sarumonkee did the wise thing of waving the probe around and did not see any changes. That tells a lot. Say the setup of the resistor is on the xy plane, the B is on z axis, you wave the probe around, the loop of the probe and the wire can be tangent to the B or on xy plane but out side the path of the B. If the magnetic field is so strong, he would have seen big changes on the reading.
Anyway, I drawn up a setup to minimize the loop area of the measurement and I attach here. I use two coax, solder the ground shield at the middle point of the wire loop as shown. the cable inside the coax should twist with the wire of the loop to ensure the area between the wire and the coax inner cable is kept to minimum. The ability of picking up mag field is proportional to the area inside the loop, by minimize the area, you minimize the pickup. This will give a better reading. If you want to. twist the two coax together to minimize the area also until ending to the scope farther away.
I am gone, I'll try harder to stay away until tonight!
yungman said:
I consider this is a friendly debate here, no hard feeling at all. I just believe we have to include the voltage source no mater what, without the voltage source, where is the current come from? No voltage source, there is nothing for us to talk about. I model this as a single voltage source, this is in line with every electronics book that I read. Just use the model of the transmission that I described, you really don't have individual resistor, inductor etc. It is just a distributed element and is expressed as ohm/length, farad/length or henry/length. This transmission line model is in EM or ED textbook too!
The current is coming from the time varying E & H fields. That's where. The Lorentz force equation is:
F = q*(E + u X B).
The reason charges move through the loop is Lorentz force, which can be expressed in terms of the fields & velocity. Regarding the inclusion or lack of a discrete source, here goes.
In distributed field terms, w/o source --> Vr1 + Vr2 = Vinduced, for a loop w/ 2 resistors.
In lumped circuit terms, w/ source --> Vr1 +Vr2 - Vinduced = 0, KVL applies.
There is no difference at all. You do not have to include a discrete source. Everything is included. Without a source, the summation of loop voltage equals the induced emf. We are acknowledging said induced emf as the sum around the loop. Without the source included, what is driving the current? Answer: the time varying fields carry energy/power. The power induced cannot exceed the watts in the incident field.
With lumped parameter equivalent circuit including a source, the sum of voltage drops equals the induced emf. But the equation is written w/ the induced emf on the same side as the resistive voltage drops, resulting in a sum of zero, which agrees with KVL. But the 2 eqns above are identical, because if a + b = c, then it also holds that a + b - c = 0, as well. The 2nd form of the equation looks like KVL. But both are equivalent.
Include the source, or don't include it. Lump the quantities, or distribute them. As long as you account for everything you should get the right answer either way. Again, Dr. Lewin's critics are making too much ado over nothing.
I designed magnetics for a living full time, then branched into broader electronic r&d while still doing magnetics as well, for 32 yrs. now. I'm in the final stage of the Ph.D. program. I had to study e/m fields for the qualifier. This stuff is not trivial, & can be confusing. But great minds have figured it out. The critics are blowing smoke, as they don't know as much as they think. Cheers.
Claude
F = q*(E + u X B).
This two is the same equation, Vinduced is there.
As I said over and over, the point D is NOT a node! I am waiting for Sarumonkee to repeat the experiment.
Claude
I don't think we can see eye to eye, I am talking about the experiment that the professor did and the drawing he had. My only question to you at this point is going back to my first schematic. If you say the source need not be there and it does not matter. So point B and point C is the same point. Are you telling me voltage from point B to point A IS the same as from point C to point A. In all your argument that their are no source, that you should get the same measurement.
[tex]\hbox { If } V_{BA}=V_{CA}[/tex]
If so, then I am blowing off hot air in this thread. If it is not, then you are going to have to explain this out. I am not working and I don't have all the components readily for me to try it easily. Sarumonkee did the experiment and found voltage across the wire, seems like you just chuck it into his measurement error. Until you can prove that there is no voltage drop across the wire and point B and C are identical electrically, all your Lorenze and FL means nothing. Generating current with any reason still a source and need to be accounted for. I am studying EM and RF for the last 10 years also after 27 years of being a senior engineer and manager of EE. You cannot just look at the equation, setup is everything. You don't know the professor's setup, you can't comment on that. From the drawing, I know point B is not equal to point C.
Being said that, I was thinking, if the loop is consisted only of resistor material, say 900ohm from [itex]0< \phi< \pi[/itex] and 100ohm from [itex]\pi< \phi< 2\pi[/itex], and measure the voltage across point A and D like the professor. I wonder what would be the voltage. I have a suspicion that the voltage is not going to be 9:1. I think on first pass, the voltage is the super-position of the induced emf of the loop and the voltage divider effect. I don't know, that would be interesting if there is resistor like this, a half circle shape. But I am sure what ever the voltage measured, it is path independent. The closest is using those high voltage resistor from brand like Caddock that is 2" long and 1/8" diameter and solder end to end to form a square loop. 3 resistor of say 50ohm and one 900ohm to get about 9:1 ratio ( not very important as long as it is taken into consideration). Then you can measure the voltage across each resistor. Now you almost get 4 notes and you can really try KVL clockwise or CCW.
I would like to inject a note of caution here.
If you do this and the loop is part of a larger network or mesh you may again obtain misleading results.
It was for this reason, until the rise of matrix theory for asembling large systems of linear equations for computers, that KVL was originally stated, and taught at MIT and other learned institutions, in the form I presented.
In your schematic the discrete source physically exists. It drives the primary of the xfmr, & the resistors are across the secondary. You have to include the source because the induction is confined to the interior of the xfmr. KVL holds here.
The Dr. Lewin setup relies on the distributed nature of induction. When the loop itself forms an inductance, or turn(s) of a xfmr, then KVL must be modified. The summation around said loop is not zero, but the induced emf. If we wish to lump the induction into a discrete source, then KVL will apply.
Studiot mentioned the large network & mesh problem. I am aware of that, but this case involves a simple 1-loop setup. We cannot obtain full agreement with the simple case, so I advise against complicating the issue until we settle this one. I have a multi-loop problem worked out somewhere, if I canot find it I'll recreate & post later. BR.
Claude
Claude
So after all these pages, and many words, I think I finally realize that we all might be saying the same thing. (Well most of us, some people that didn't stick around past page 4 said some pretty weird things).
Basically, my problem with Lewin's example was he didn't account for the inductance of the wire, making it look like a node had two voltages. From an electrical engineers perspective, that is heresy, as we always attempt to make a model that mimics reality as close as possible, be it lumped element, or what. I am getting the feeling that physicist's sometimes disregard some aspects of a circuit, but I don't have a good sense on why yet.
All the talk about Lewin setting up a strange definition of KVL is making more sense to me, as KVL does not hold, IFF you claim there is no inductor lumped element.
I still contend this makes Lewin look like he doesn't know how energy is being coupled into the circuit, or is being a totally misleading jester...
All in all, I will continue to use the lumped element models for cases like this, as this is most definitely the "most intuitive" thing to do for me :).
versus ?
You have been so critical of Prof. Lewin, but do you even notice your own contradictory statements?
stevenb said:
versus ?
Nope... please enlighten me.
I thought we were under the consensus that there is inductance in the line, Lewin did not have it in his model, and so KVL did work. Are you saying there is no voltage drop across the wires connecting the resistors?
Where are my statements contradictory? I chose to model with lumped elements, instead of completely ignoring their existence... You are confusing me again...
There is an inductance and resistance that Lewin is negelecting by not putting the voltmeters at exactly the same point. Let's call this inductance Lp. It can be modeled as a lumped elements.
There is a completely different inductance due to the big loop of two resistors and wires. Let's call this inductance Lq In Lewin's case Lq is far greater than Lp, so he neglects Lp. He treats Lq using Faraday's law. Some aspects of Lq can be treated by making it a lumped element, but not all. Lq causes the voltmeters to have different readings even if they are connected to exactly the same points.
If you won't believe a physicist, how about two electrical engineers (unfortunately from the same institution) http://web.mit.edu/6.013_book/www/, section 8.4: "In fact, as we now take care to define the circumstances required to make the terminal voltage of a coil a well-defined variable ... If a time-varying magnetic field is significant in this region, then different arrangements of the leads connecting the terminals to the voltmeter will result in different voltmeter readings."
I did enlighten you. Look at the two statements that I quoted from you. You don't see the contradiction? I can enlighten you more if you can't see it.
Lumped models are not models that mimic reality as closely as possible. The fact is that we use approximate models all the time, both in engineering and in phyisics, so your statement that electrical engineers always use models that mimic reality as closely as possible is at best naive, and at worst blatantly wrong.
The fact is that Prof. Lewin was guiding the students to think of an electromagnetic field based model (Faraday's Law), essentially invoking the spirit of Maxwell's equations, which blow any "lumped parameter model" out of the water, at least in terms of better matching the real physics.
I know what Cabraham is driving at that in case their is no wire and the whole loop is made up of resistors. Please read my post at #125. I was thinking if we can solder resistor back to back with very very short leads. so the loop is mainly consists of resistor body and see what is the measurement. You might have better access with resistors than me since I am not working and I can't access to a lab. It would be very nice if you can find some long thin resistors. but if not, you can still use those half watt carbon resistors and solder a loop. Make sure you don't use any of the wire wound resistors because they are really inductors in reasonable high frequency. You have to use either metal film or carbon resistors. Use one with about 900ohm and 6 or 8 of identical low value to make up the 100ohm. Solder tightly to a loop.
This time instead of using a scope probe, take two wires, fix one side and use an electric drill clamp on the other end and twist into a twisted pair of wires. Use the twisted pair in place of the probe and solder onto the resistors. Do the measurement and see. The reason of the twisted pair is to minimize the loop area of the prob so you don't pick up mag field. This way you get much better measurement. You can experiment waving the twisted pair around to see whether the voltage change also.
If you have two channel scope, you might have to useing two twisted pair and do measurement on two resistors at a time. You just walk through the resistors like:
1) First measurement is on R1 and R2 together and write down the voltage.
2) then move one pair to R3 and write down both reading of R2 and R3.
3) Then more the pair on R2 to R4 and write down again both reading of R3 and R4.
You repeat the measurement until you reach the last resistor and back to R1 again.
The reason for doing this is because when you solder and unsolder onto the resistor, you move the setup and even you input identical mag field, when the loop move, induction coupling change. If you do this walking through the resistor one at a time like I described, you can back calculate the voltage ratio instead of depending on the absolute reading.
When you build the resistors loop, twist the leads of the resistors together before you solder. You can leave the twisted end a little longer because it is not part of the loop and should not change the reading. This is because when you solder the leads on and off, you might undo the loop and change the characteristic when you put it back. With twisted leads, the loop will not undo when you try to solder the probe leads on.
I hope you have time to do this. This will show whether if the loop make of all resistors make a difference. I am not sure you will get the correct ratio of voltage. But I am sure it will be path independent. It this case, there will be no wire, every point is a node. We can put this whole thing behind.
I still believe Lorenze force can be modeled as a source. It is a very simple law that in the presence of mag field:
[tex]\vec F = q(\vec u X \vec B)[/tex]
Can be consider as a distributed source and can be modeled as a lump source. Because this say nothing but current being moved in the presence of mag field...Nothing more. I attach a drawing.
If you like, you can use distributed model of putting infinite voltage sources spread around the whole loop and draw out the circuit. Remember now, it is the EM books that use this distributed model to model the transmission line. They model as R per unit length, C per unit length etc. Then they make the length approach zero to derive the wave equation.
You draw the distribute model of the loop out, you can see immediately that you can just move all the distributed source to one side and become a lumped source. See my drawing.
I am not sure in the resistor loop, you will get the voltage ratio of the resistors. You can argue the Ohm's law don't work, but I argue that it could be because the voltage source ins laced inside the resistor that can throw the reading off. I am not sure in this case, but it would be interesting to see if Sarumonkee is willing to do the resistors loop experiment.
Sure, I wouldn't object to that at all. I'm also not opposed to a single lumping of EMF in some cases. It all depends on what you are trying to do.
A video demonstration by MIT, which might be some help (see section 10.0.1): http://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-013-electromagnetics-and-applications-fall-2005/textbook-with-video-demonstrations/
@yungman: IMHO, the reason we can group all the elements is that they are continuously distributed. However, in this case, the NET (total) emf is disrupted. Have a look at my picture. The induced emf is continuously distributed, but the extra emfs due to charge accumulation are not.
When we write the equation for a loop, since the E-field of the charge is conservative, the extra emf vanishes for a complete loop, and that's why we have such things as equivalence between KVL and FL, as stevenb and cabraham (if I'm not wrong) pointed out.
@stevenb: Hurray to you for pointing out the subtlety behind this debate.
Do the extra EMF and induced EMF equal each other in this picture?
Theoretically, the part of induced emf on the wire cancels out the extra emf #1 and #2. Notice the direction. I'm on vacation and don't have access to the lab, so I'm still waiting for your experiment for verification :biggrin:
Now we are all into back patting mode perhaps we should look seriously at yungman's transmission lines.
Some of these, extending perhaps across half a continent or more, are sufficiently long that the conditions at one part do not have time to affect a remote part if we take simultaneous 'readings' .
@cabraham
Thank you for noticing my comment about multiple mesh loops. This is not a problem if you take the original galvanic version of KVL for each loop.
@yungman
If you talk to the engineers at your works I expect they will be working in terms of admittances rather than resitances/impedances and using different mesh analysis methods anyway.
Oh and can anyone tell me why I now have a pink label?
So in Lewin's setup, is he measuring the extra EMF across the resistors?
I won't be able to do more tests until probably this weekend.
As I've stated many times, lumping the induced emf into a discrete source produces a correct result. But in order to do that you first have to know the value of said induced emf. If you have a loop to measure, & you find that the sum of voltages around said loop is non-zero, then you know that induction is taking place.
So you measure the sum around the loop, & that is the value you insert into the lumped source. But you first had to measure the distributed quantities in order to get the right values for the lumped equivalent circuit.
Once all parameters have been measured, one can continue using the distributed form, or one may lump the quantities into an equivalent circuit with no loss of accuracy. They both work.
My point is that many have stated that they would rather just use the lumped circuit & forget the distributed model. I only wish to point out that the distributed loop must first be measured before the lumped emf source value is known. So the distributed loop is needed in order to get the necessary data.
Is this debate still going? As far as I'm concerned this case is closed. Everyone agrees.
Claude
He was measuring the net emf (= extra emf + induced emf), I believe. A theoretical proof of what I say:
Take the integral over the loop around resistor R1 and its corresponding voltmeter: [tex]\oint Edr = V_1 + IR_1 = 0[/tex] , according to FL (as there is no magnetic flux change through this loop). Here V1 is the "voltage" measured by the voltmeter. The microscopic Ohm's law implies that the total E-field (= E-field by charge + induced E-field), or the total emf, is the one that drives the current I through R1. Therefore, V1 corresponds to the total emf.
atyy said:
@stevenb: MIT seems to be rewriting history, 5 minutes into http://ocw.mit.edu/courses/electric...tronics-spring-2007/video-lectures/lecture-2/, he gives the zero definition of KVL (admittedly this is what I learned too, I wasn't aware of the history of this till your earlier posts)!
Good point. I think Prof. Agarwal's treatment is excellent. First of all, he starts with the assumptions of no time changing flux outside any lumped element and no time changing net charge inside any element, which is necessary for the two Kirchoff laws he quotes. Then, when he sums voltage to zero, he says the word "voltage" rather than potential. This is OK because the term voltage is general enough to include EMF and potential. So Prof. Lewin's example does not meet the assumptions here. I wish the authors of all books would be as careful as this professor is in his lecture.
This is why I didn't try to make a big deal about the semantics of what KVL is. If you clearly define what you mean and the assumptions that are relevant, and then go on to apply the rule to the correct case, there is no problem.
I can definitely see the usefullness of this statement of KVL in cases where the assumptions are valid. We could get into battles over semantics here, but I really hate doing that. In some sense this is a third definition of KVL. I can list them as follows.
1. The Classical/Maxwell Definition Generalized to any EMF source is the statement that the sum of EMFs equals the sum of potentials.
2. The Modern Lumped Element Definition is the statement that the sum of all voltages equals zero if there is no time changing flux outside a lumped element.
3. The Conservative Field Definition is the statement that potentials around a loop add to zero if there is no time changing flux outside or inside a lumped element.
At the risk of taking criticism, I could argue that the historical change was justified considering that most practical circuits of the earlier 20'th century met the lumped circuit assumptions. Perhaps, we are in need of another change back to definition 1 as modern cicuits using high frequency digital processing and magnetics-based switching power supplies are so prevalent. I've seen PCB layout people make the mistake of routing connections to A/D converter inputs (which measure voltage) around power magnetic sections, leading to measurement error. A good engineer should catch that mistake during review before it goes to production, but he won't if he thinks only in terms of definition 2 above, and forgets the starting assumption (or never learned that assumption). Keeping Faraday's Law in the back of the mind can save an engineer lots of grief.
@cabraham
@yungman
When come to the case of the loop make up of all resistors material with no wire in between, I have to say I am not as sure. As you can see from my drawing in the last post, with micro generator laced in between the micro resistors, I just have a feeling that you are not going to get 9:1 measurement, but now that we have two distinct nodes, I am sure it still not path dependent. I believe you can still measure the same voltage both direction.
Anyway, I am really trying to not to check this thread as often, I had not have a good study section on my own materials for the last 3 days!:smile: I really better type less and work more! I try not to be here until at least tonight! But then again, my fingers might have the mind of their own!
Yungman, you quoted my last post in its entirety, but did not make any reference or reply in your own text?
Sorry, I just continue from what you wrote, that I back paddle on the loop make up of all resistors materials with no wire, that I question whether we can get 9:1 voltage ratio because of the distributed sources. I still stand by the prosfessor's experiment with two resistor and a wire. That is a more clear cut case.
My guess ( only) is that the voltage is a super position of the transformer ( if you want to call Lorentz loop or what ever) and the two resistor. Meaning the voltage ratio might be 4:1 or 3:1 instead of 9:1. but it is still not path dependent. Sarumonkee said he might find time to do the resistor chain experiment soon. I just think you are not going to get 9:1 ratio on the 900ohm resistor in this case since the 15ohm take up most of the loop. Just a wild guess.
But what has any of that to do with what I said?
Incidentally you do not need to play about soldering resistors. Just get some nichrome wire or lay down a shaped carbon track.
I'm open to donations :)
I thought about the carbon track, but I have no way of making it very regular. I was thinking of just writing with a graphite pencil on some transfer paper, but don't think that would come out very well.
How about some auto highZ ignition leads?
