Can Trigonometric Identities Validate This Proof?
  • MHB
  • Thread starter Sudharaka
  • Tags
    Proof Trig
In summary, the equation \(\dfrac{\sec(8A)-1}{\sec(4A)-1}=\dfrac{\tan(8A)}{\tan(2A)}\) can be proved by manipulating the left hand side using trigonometric identities and correcting a mistake in the denominator of the right hand side.
Sudharaka
MHB
1,568
srirahulan's question on Math Help Forum,
Prove that, \(\dfrac{\sec(8A)-1}{\sec(4A)-1}=\dfrac{\tan(8A)}{\tan(4A)}\)
Hi srirahulan,
Consider the left hand side of the above equation,
\begin{eqnarray}
\frac{\sec 8A-1}{\sec 4A-1}&=&\frac{\cos 4A}{\cos 8A}\left(\frac{1-\cos 8A}{1-\cos 4A}\right)\\
&=&\frac{\cos 4A}{\cos 8A}\left(\frac{2\sin^{2} 4A}{2 \sin^{2} 2A}\right)\\
&=&\frac{\sin 8A\,\sin 4A}{2\sin^{2}2A\,\cos 8A}\\
&=&\frac{\tan 8A}{\left(\dfrac{2\sin^{2}2A}{\sin 4A}\right)}\\
&=&\frac{\tan 8A}{\left(\dfrac{2 \sin^{2}2A}{2\sin 2A\cos 2A}\right)}\\
&=&\frac{\tan 8A}{\left(\dfrac{\sin 2A}{\cos 2A}\right)}\\
&=&\frac{\tan 8A}{\tan 2A}\\
\end{eqnarray}
\[\therefore\dfrac{\sec(8A)-1}{\sec(4A)-1}=\dfrac{\tan(8A)}{\tan(2A)}\]
So your question has a mistake in it. The denominator of the right hand side should be \(\tan(2A)\).
1. What is a Trig Proof?
A Trig Proof is a mathematical method used to verify the validity of a trigonometric equation or identity. It involves using established trigonometric properties and rules to manipulate and simplify the given equation until both sides are equal.
2. Why are Trig Proofs important?
Trig Proofs are important because they allow us to understand and prove the relationships between different trigonometric functions and identities. They also serve as a foundation for more advanced mathematical concepts and applications.
3. How do you approach solving a Trig Proof?
The first step in solving a Trig Proof is to identify the given equation or identity and determine what needs to be proven. Then, use the known trigonometric properties and rules to manipulate both sides of the equation, working towards the same end result. It is important to keep in mind that both sides of the equation must be equivalent in order for the proof to be valid.
4. What are some common strategies for solving Trig Proofs?
Some common strategies for solving Trig Proofs include using trigonometric identities, converting trigonometric functions to their respective ratios, and using algebraic manipulation techniques. It is also helpful to break down the equation into smaller, more manageable parts and work through each step carefully.
5. Are there any tips for successfully completing Trig Proofs?
Some tips for successfully completing Trig Proofs include practicing regularly, understanding the fundamental trigonometric properties and identities, and breaking down the problem into smaller, more manageable steps. It is also important to check your work and make sure both sides of the equation are equivalent before concluding the proof.
  • General Math
  • General Math
  • General Math
